Results 1 to 6 of 6
Thread: Speaker wiring
    Sep 2007
    Sunny Florida
    Speaker wiring
    Okay this is my second carpc install and the first one went a lot easier. By keeping the head unit in the dash I was able to run the audio using the aux port on the head unit.
    I have a 2007 ford mustang and I would like to remove the headunit and replace it with a carpc.
    I'm trying to figure out the best way to do it without a headunit. Does anyone have any ideas?
    Jan 2008
    Southern Calif
    I don't know what you mean by speaker wiring but you do know that you need an audio amp if you wanna go head less.
    Vendor - Qube colin's Avatar
    Dec 2006
    Look into it a bit more. The audio systems on Mustangs is a bit more than most cars. If you have one with built-in amps, you may have a bit more difficulty, if not, you can just do it like every other car and run the line-out of your PC to your amp...
    Sep 2007
    Sunny Florida
    Yeah I have the shaker 500 system with the built in amp. There was a thread around here that had some good info but I can't find it for the life of me. I was hoping someone could chime in with a link or something. I will keep looking though thanks guys.
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    Sep 2007
    Sunny Florida
    Quote Originally Posted by roflcopter View Post
    That's not what I was looking for but that will work. Thanks for the link I found my solution in that thread along with a lot of other info I was looking for.
  1. Use Factory Speaker Wiring?
    By utd09bry in forum Car Audio
    Last Post: 02-02-2008, 02:09 AM
  2. speaker wiring
    By konzine in forum Car Audio
    Last Post: 03-21-2007, 10:57 AM
  3. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  4. STi Speaker Wiring Setup?
    By i_drank_what in forum Car Audio
    Last Post: 09-01-2005, 12:10 PM
  5. car audio wiring harness -> computer speaker port ??
    By nadir_s in forum General MP3Car Discussion
    Last Post: 01-07-2004, 10:48 PM
