1) wired FM Modulator
2) Short answer no. 1st, a desktop drive uses tons of power. Multiple amps at full spin. They are fast, big, and work really well which means they consume power. Who cares at home right? A laptop drive is built for the mobile environment. A disk wont boucne around when driving, it wont take as much power, can be powered from the usb bus, and are smaller so easier to fabricate. IDE and SATA connections are limited by length. A span from dash to laptop is probably 3ft to 5ft minimum. 24" is the max really for IDE, SATA I am sure is about the same. USB is about 3 metres, so it will work ok.
LinkBack URL
About LinkBacks
