Install OS.
Install Front End.
Configure PC.
Test.
Rinse & Repeat as necessary.
Install.
Gl.
Hi, I just bought my first car pc and it has a built in Toshiba 120gb harddrive (Model Number: MK1246GSX). It utilizes a SATA 2 connection, and none of my current computers do. I would like to be able to install Windows XP and Road Runner with all of my music and videos, before I take it out to the car. Any help would be greatly appreciated.
Install OS.
Install Front End.
Configure PC.
Test.
Install.
Gl.
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
yes. Hot to power and ignition, ground to ground.
My opinion is my own.
Are you talking about the plug that you plug into the back of your laptop? What PS do you have? Make sure it can handle voltages other than 12v DC!![]()
The laptops cable is split into two parts: 1-the wall outlet plug to a connector, 2-the brick and the barrel plug. So I can use the wall outlet plug to the connector and stick the three leads in to it, without utilizing the brick? I hate to ask, but I want to make sure I do this right. Thanks.
Well the Wall outlet is AC. What Power supply do you have?
As far as the laptop goes, I'm not sure. The Car PC has a (M2-ATX).
ah ok, now what voltage is your laptop brick outputting? It usually says on the brick
INPUT is: 100-240V~1.6A-0.8A
Output is: 16V 4.5A
