Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Have a question about wiring
  1. #11
    Jul 2008
    Could I tap into my amplifiers power line (I'll still use a in-line fuse, it would just be a shorter wire length), if not I'll look into using the distro block?
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    Here is the issue with using 16 gauge to hook up the M2-ATX and I was tricked by it when I did my first installation, too. The longer the wire, the more resistance. Resistance makes wires heat up and if you don't use the proper gauge wire, you could end up with a fire hazard, worst case.
    The M2 has smaller gauge wires going into because they are SHORT. This leads people to believe that they can extend them with the same gauge wire. Untrue, for the reason above.
    To figure the proper gauge wire, you should use a power calculator and the anticipated load on the wire. That will tell you the right gauge to use. If you don't feel like doing that, then at least look at the table in the FAQ that advises on the right gauge to use.
    You will need to know how many amps your system will draw, but since you are using the M2-ATX, it is a 160 watt device. For safety, assume 200 watts. Using Watts = volts X amps, you can solve 200 = 12 X amps or 16.6 or 17 amps. According to that table, you can run up to 30 feet with 8 gauge wire but only 4 feet with 16 gauge wire.
    Want to:
  3. #13
    Jul 2008
    So could I still hook it into my amps power wire. Its only about 2ft. distance from the computer. I'll still put a 15 Amp fuse in to help. Thanks again for the help.
  4. #14
    Vendor - Qube colin's Avatar
    Dec 2006
    You could, IF your amp has a power wire that is overrated by at least 20 amps. If you have, say, a 4-gauge wire going into a 400 watt amp, then sure. If you're running 8-gauge or something, then I wouldn't risk it.
  5. #15
    Jul 2008
    Its definitely 4-Gauge Wire, so I'll do that and see how much stuff I blow up, just kidding.
  6. #16
    Newbie RVRNET1's Avatar
    Jul 2008
    Ione, CA
    I will have to agree, using 16GA is looking for serious trouble. Always have an ABC fire extinguisher on stand-by.
    There's no place like or ./usr/home
  7. #17
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Maybe it all depends on preference. My truck has a 4 gauge coming from the battery to a heavy fuse then from the fuse to a 4 guage to a circuit breaker and fuse. Then from there it splits, to the rear goes another 4 gauge to a fuse, then to the rear amps. In the mean time a 8 guage wire goes from the circuit breaker also to the passenger seat were all my CarPc connections are.
    If you check out my worklog you can see it in there.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  1. 04 Grand Prix Wiring question
    By djviper108 in forum Car Audio
    Last Post: 06-19-2007, 04:44 PM
  2. simple wiring question
    By yonu in forum Power Supplies
    Last Post: 01-19-2007, 05:00 PM
  3. Wiring question
    By pirate_king00 in forum General Hardware Discussion
    Last Post: 02-17-2005, 03:01 PM
  4. Wiring question
    By barometer in forum Newbie
    Last Post: 07-14-2004, 06:35 PM
