Results 1 to 10 of 10
Thread: Powering 5-10 Computers
    Jul 2008
    I've been toying with an idea of mine latley, which would involve 5-10 computers on board a trailer. What would be the best way to power such a project?
    Generator perhapes?
    Nic
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Depends on a lot of things. Screen sizes, specs of the PC, drives, usb devices, etc.
    If you go with some of the low power solutions, could probably get away with tapping into a 12v source and forget expensive generators.
    Probably need more info about your idea before anybody hands out any golden advice. Just not enough info.
    Tidder
    Try RevFE
    Jul 2008
    Low power machines wouldnt be an option.
    I'm looking to power 5-10 high end gaming machines. So it would be all high end parts, flat screens (19-22in) and maybe even a 42' big screen as well. So it would def be a power guzzler.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Generator for sure. Figure 1000 watts per machine, plus the screens plus a good 50% overhead. 10,000 watts wouldn't be out of the question, here.
    Want to:
    Jul 2008
    10 computers max, and as I mentioned, maybe one big screen tv.
    Jan 2008
    Norton, MA
    would you have access to a land line with this sort of a setup? Even then your still looking at a lot of power though. Sounds like a pretty cool idea though. Guessing it would be like a portable lan party.
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
    Jul 2008
    exactly. it would be a portable lan party. Not looking to hook up to the net, although would like to. But basically it would be one side vs the other side.
    Elsewhere
    Definitely a generator that will output about 10,000 watts minimum. You're looking at a generator built for a high-end motor home.
    As far as internet you can use a router like the Kyocera KR-1 and use a mobile broadband card.
    Your idea is hardly original. I had this idea a few years ago: http://www.mp3car.com/vbulletin/gene...ted-brain.html
    How about the Wiki?
    Jun 2008
    An interesting concept, if not exactly a new one.
    As for the electrical power needed- yes, it will be substantial, as will the cost of the computer parts alone.
    But here is a consideration:
    Since all gamers will be present and using the provided machines, they don't actually NEED to be full-blown powerhouse Uber gaming rigs.
    They need memory, hella good video cards and fast, pretty monitors.
    The rest of the components merely nee to be sufficient really, and when you are talking about gaming rigs, a sufficient system will cost about a third (or less) of what an Uber rig will.
    And they will use less power as well, helping to reduce the size of the generator you require to power 10 computers, 42" screen and an air conditioner sufficient to keep it all from melting in an hour.
    Jul 2008
    lol, ya I don't need ubermachines as you said. Thanks for all the help guys
  1. How could I build a 10 minute time delay relay?
    By nobb in forum Power Supplies
    Last Post: 11-13-2007, 11:16 PM
  2. FS: 10 X AU Optronics 7" TFT LCD's
    By 24Seven in forum Classified Archive
    Last Post: 09-27-2006, 02:11 PM
  3. 10 Second Clips from DVD's...?? software
    By Escalade182 in forum Off Topic
    Last Post: 02-28-2006, 05:18 PM
  4. Replies: 4
    Last Post: 09-19-2005, 07:41 AM
  5. updrading windows media player 10
    By JoyRidun in forum Software & Software Development
    Last Post: 11-26-2004, 01:20 AM
