Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: i need help
  1. #11
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    This is essentially what you want:
    [media]http://www.yycomputer.net/products/cable/s-video-rca.jpg[/media]
    Love
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by wkndpaintballer View Post
    so does a svideo cable have audio?
    Quote Originally Posted by rEegLer View Post
    Yes but it needs to go into your audio jack on your laptop. Those cables are really three cables in one. One goes to from S-video to RCA video and the last two go from your audio jack to two RCA audio plugs (right & left)
    Just to be clear here, svideo contains no audio.
    But you can buy a cable that as reagler said has multiple cables wrapped inside it, which has video and audio. But again on the laptop side and the headunit side, you will be plugging in more than 1 wire each time. Also the touchscreen will not work, and again the video will suffer big time. Hook your laptop up to your tv using the svideo cable. Look at how it looks, and you will believe us.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Aug 2008
    Meridian, Mississippi
    ok here is what im thinking get a usb hub and an external video card and external audio card that will all stay in the truck.. when i put my computer in the truck all ill have to do is hook up the 1 usb hub to my computer and ill have video and sound... would this work
  4. #14
    Jul 2008
    Mechanicsburg, PA
    From what i know, USB video cards aren't cheap and they are bottle necked because USB can only all so much bandwidth to go through it. They make those for people who don't have analog signals and only digitial. But i also have never used them so who knows. If you get that cable I posted above, all you have to do is disconnect/connect the s-video and audio cables. Using the usb video and audio connector seems like a more complex and more expensive way to go. Plus you would have to use two usb ports, one for video and one for audio.
    If this is really the course you want to take, then have at and if you get it to work, write a tutorial!
    p.s. toaster, its reegler, not reagler its ok though, i forgive you
    Love
  5. #15
    Aug 2008
    how long can u get one of those cables bc im gonna be runnin it from the dash to the very back of the truck
  6. #16
    Jul 2008
    Mechanicsburg, PA
    I think they typically they come in 6ft (2m) lengths. You can always buy extenders.
    Love
  7. #17
    Newbie NATISFYNEST's Avatar
    Aug 2008
    da nati
  8. #18
    Aug 2008
    ok i found a solution i can hook up my xbox 360 to my radio then using the windows media center extender i can play all the music from my laptop on it and control it with the xbox remote
  9. #19
    Mar 2006
    The 360 is a pretty horrible device to put in your car. You will need a dedicated line for it from the battery/.
