Results 1 to 10 of 19
Thread: i need help
    Aug 2008
    Meridian, Mississippi
    i need help
    ok i have a double din screen in my car what i want to do is hook up my laptop so that it will display the desktop on the screen and mount a touch pad in the console so i can put the laptop in the back and listen to my music on it. my question is is it possible to do this thru a usb port where i have 1 cable to plug into my laptop and have video and audio converted into rca
    Mar 2006
    Colorado, but Canadian!
    They make usb->vga adapters and also usb sound cards and usb touchpads. It will all be very choppy running with the video too.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2008
    well i have a vga output on my laptop... basically what i want is like the adapters used to convert analog media ie from a video camera to digital but i want it to go in reverse convert digital into analog... from what i can tell the nintendo wii has a usb to A/V rca cable to connect to the tv
    Mar 2006
    Quote Originally Posted by wkndpaintballer View Post
    Outward conversion is a video card. That simple. If you want it in USB form, then get a USB external video card...
    And no the wii doesnt do usb to video output. Not all tiny connectors are USB. They just use a connector and put their own info over the line. There is no such thing as a video adapter "cable" that will go from usb (a data standard) to vga (a video standard).
    If you want more than 1 cable to connect each time, then get a "pc to tv" converter. But the quality will crap crap crap. I would not even think about doing this unless you are getting a VGA quality screen.
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    You need to tell us a little more about your screen and laptop. Does your screen have VGA inputs? If it only has RCA inputs than your quality is gonna suffer no matter what. Does your laptop have S-Video out? They make cables and adapters that go from S-Video out to RCA.
    Love
    Aug 2008
    ok my screen is a jvc double din touchscreen head unit with 1 set of A/V rca input... i have a compaq f756nr it has 3 usb ports a vga output and s-video output... my objective is to have to plug in only 1 cable into the computer and have audio and video to my head unit... i do not plan on using the head unit to control the pc only to view the screen
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    If that's all you're trying to do, cables with s-video connectors on one end and phono (A/V) connectors on the other are cheap and plentiful; most decent-sized supermarkets have them. Be warned though, the video quality will not be good.
    Jul 2008
    Mechanicsburg, PA
    Why only 1 cable? The easiest way to do it is to do what Grrrrrrrrrrrrrrrrrrrrrrrrmachine said. Buy the cable at walmart or bestbuy or something. It will be good enough for watching movies and playing music, anything past that and you're gonna be guessing whats on the screen.
    Love
    Aug 2008
    so does a svideo cable have audio?
    Jul 2008
    Mechanicsburg, PA
    Yes but it needs to go into your audio jack on your laptop. Those cables are really three cables in one. One goes to from S-video to RCA video and the last two go from your audio jack to two RCA audio plugs (right & left)
    Love
