Results 11 to 20 of 27
Thread: New guy!
  1. #11
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    well i think you're going to want to get up to that 512 mb point.
    As for the s-video question, you might be able to run a series of adapters that go from s-video to RCA video then to your 3.5mm jack. I would just google a bunch of adapters.
    example:
    (http://www.svideo.com/3avw3506.html)
    Love
  2. #12
    Aug 2008
    That's the method I'm currently working with.
    S-Video Cable --> S-video to Composite adapter --> Composite to 3.5mm cable.
    The onboard graphics is an S3 Savage IX but the TV settings are greyed out as if it cant deted the screen.
  3. #13
    Jul 2008
    Mechanicsburg, PA
    wait, so can you get it to switch to your s-video screen or not?
    Love
  4. #14
    Aug 2008
    No I can't. All settings relating to TV out are greyed out and cant be chaged/turned on etc.
  5. #15
    Jul 2008
    Mechanicsburg, PA
    hmm, that usually means the computer didn't find a valid video signal to send it to. Can you try hooking it up to a normal TV just to make sure you cables aren't bad?
    Love
  6. #16
    Aug 2008
    Output to normal tv is fine.
    I was thinking that maybe it could be all the connection changes are reducing the signal to below detectable level for the chipset?
  7. #17
    Aug 2008
    I've tested it with a normal tv and all seems to be working fine.
    Do you think all the different cable connections could be lowering the signal level too much?
  8. #18
    Jul 2008
    Mechanicsburg, PA
    hmmm i dont think so. Most likely it's a problem with the tv your using. Can you test it with a dvd player or something to make sure you're getting a signal to the tv?
    Love
  9. #19
    Aug 2008
    That I havent tried yet, I'll hook it up to something later when I get home from work and see what the outcome is.
    Cheers for the help Reegler, I'll let you know how it goes.
  10. #20
    Jul 2008
    Mechanicsburg, PA
    You're welcome, hope all goes well
    Love
  1. Replies: 28
    Last Post: 08-22-2006, 10:33 AM
  2. 100 Great Reasons It's Great To Be A Guy
    By BoyNextDoor in forum Off Topic
    Last Post: 06-16-2006, 07:18 PM
  3. Wow!, wouldnt be this guy ! :) hehe
    By t0ffluss in forum Off Topic
    Last Post: 01-16-2006, 09:48 AM
  4. Help to make poverty history
    By thanatos106 in forum Off Topic
    Last Post: 09-01-2005, 03:39 PM
  5. Wow!, wouldnt be this guy ! :) hehe
    Last Post: 03-04-2005, 05:26 PM
