Results 1 to 10 of 18
Thread: Power fans off of car?
    Jul 2008
    Ok here is what I have setup right now. I'm already fairly certain i'm going to need a dc to dc converter for this to work best, but I'd like the advice from someone else to ensure this.
    I have an amp and an enclosure I have made for it that will house my pc components also. I do not have the components for the pc yet because I am contemplating on whether I want to do it or not because of the screen being read in sunlight. Not sure I want to shell out $700-800 for a transflective. Anyways, I don't have a dc to dc converter and I was wondering if the best way to power 4-60mm and 2-80mm fans would be to use a dc-dc or if there is a better easier/cheaper solution for the time being. I had asked someone in person and they said the 12v in the car should do just fine, but that fluctuates in a car from 11.5-14.5v or so and that would be running my fans at an unnecessary speed and most likely cause them to have a shorter life span and probably make a lot of unneeded noise also.
    What are some thoughts on this?
    Jul 2002
    I agree with your assessment of the issues. The shortened life probably won't be significant. I doubt the extra noise will be significant either, but that is pretty subjective so you might find you don't like it.
    If you can live with the reduced air movement, a higher voltage fan (24v) would run slower and last longer, but I don't know about availability.
    You won't need a very good dc-dc converter (tight regulation, low ripple output) to run fans so an inexpensive one would do and give some control over the speed if you get one with a bit of adjustment.
    Vendor - Qube colin's Avatar
    Dec 2006
    A low-dropout regulator would probably do it...
    although running your fans at 14v probably wont do them any noticeable damage.
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    Just tap into your 12V that is going to your PS for your future PC. Get a distribution block and just hook up your fans to it. Just make sure its sealed off so you don't get random wires touching it.
    I wouldn't worry about damaging your fans, unless they're extremely high quality fans. They'll probably last longer than your car will.
    Love
    Aug 2008
    If these are standard PC fans, then there will be a couple of fan connectors on the motherboard.
    See the connector on the left in this image, which is 12v regulated, and sometimes controlled by the motherboards BIOS depending on heat:
    [media]http://www.elma.it/IMAGES/fantt/4in4a.jpg[/media]
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have 4 fans connected directly into the 12v line. When I turn on the car, they turn on right away. These cool the amps and other devices. The other 4 are connected to the PSU, they cool the case and the PC, they dont turn on until the PC powers up. I notice that the fans directly from the 12v line seem to spin faster then the ones on the PSU.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jul 2008
    yeah... I have some vantec stealth silence fans double bearings. They aren't really cheap fans but aren't extremely expensive. I think I may purchase the M2-ATX for my possible future carputer and then just splice into one of the 12v lines on it that would go to the mobo of the pc (don't have a mobo) I think this is the best solution. What does you guys think? Is the M2-ATX a good solution for car pc applications or would you recommend something else? Thanks
    Sep 2007
    West Springfield, MA
    If you're planning on powering all those fans as well as your PC, you might want to be careful not to overload the M2. It depends on the power requirement of the PC itself. Personally, something like a fan won't be harmed by the relatively small fluctuation in voltage that a car would see. I would run them right off of an IGN source. Again, just make sure the source has enough power. I would use my 12v outlet, because it can handle 10 amps and is fused just in case.
    I remember making many of my Tyco R/C cars go faster by making the motor use higher voltage. It made more noise because of the higher speed, but that's it.
    Jul 2008
    yeah... I think that the 160w m2 ought to be enough. I'm getting a kino board with core 2 duo, 2 gig ram, 120gb hdd 7200 rmp, obdII, gps, tuner, and a few other things. I have heard that it will be enough for this but I have not gone through and calculated it. I think I may just see what the fans do when the car is on and hooked up the the cig voltage. I don't have anything else running on it so it'll be fine I think. I'll have to check the amp rating on the fans, but I believe it is only a 1/2A at most for each and there are only six of them.
    Dec 2006
    6 fans, 1/2 A each = 3A. 3A * 12V = 36 watts.
    Trust me, that makes a difference.
    Your M2 is capable of 160 watts every here and there, with optimal cooling and solid line loads (no fluctuations). You wouldn't want to put more than say... 140 watts on it max. With those fans, you have 100 watts left. With a CPU (45 watts if it's low power) and a motherboard (25-30 watts with onboard sound)... well, add the harddrive and the GPS and you're done.
    Careful...
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. Connecting AC Power Source to Car Battery
    By SolusCado in forum Power Supplies
    Last Post: 08-06-2008, 01:23 AM
  3. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  4. morex car power kit vs. ITPS
    By NaFooEsi in forum Power Supplies
    Last Post: 06-16-2004, 12:51 PM
