Look at the specs for the laptop. Does it have bluetooth? Is your GPS bluetooth, is it serial, is it USB (only you know atm)? Does the laptop have ports to match?
Composite video/TV out (assuming the laptop has the port - you didn't give enough info for the laptop, and I'm sure you can read the specs). It will look very very bad for anything involving text or fine detail.
Yes.
Same question as second bit of question 2. Same answer as before (very very bad).
No.
LinkBack URL
About LinkBacks
