Hi! Welcome to the site. The only thing that sticks out so far is how you will be turning on the Powersupply. I use a P1900 which is a little different from this one but I don't know the specs. On the 1900 there is a connection to an accessory line that tells the power supply to start up. I would think the 2140 would have something similar. The RJ45 jack might turn on the laptop, but unless the P1240 is always on (which I don't think it is) it won't provide power on the laptop.
As far as I know, the guage depends on the length of wire you are using along with the voltage/amps going through the wire. There is a calculator somewhere that shows you...do a "guage" search in the power supply forum for more info.
You don't list what kind of car you have...how do we know what the best spot for it is? Details...
LinkBack URL
About LinkBacks
