Results 1 to 3 of 3
Thread: So confused!
    Sep 2008
    So confused!
    Hi all, please forgive this newbie's absolute confusion.
    So, I'm getting a new car (2008 Grand Prix), and it really got me interested in the whole Carputer scene. I'm one that considers myself electronics savvy, but this is incredibly overwhelming.
    Essentially, I've just a few questions to make sure I have everything clear before I begin my research.
    First of all, I want an XM/GPS system installed, but I'm just wondering about how to control it. Are there kits out there for XM etc that connect to a PC that can be controlled by software in a carputer?
    Second of all, how on earth do I get this crap installed? I really have no knowledge of the inside workings of a car's electronics. Is it advisable to have this installed professionally, or is it not too hard to learn to do it?
    Lastly, what about an interface. I know you can download an interface to run on your system, but what about programming your own? Are there any particular languages that are the best for this type of thing? I'd like to pick one up and try to program my own interface down the road.
    Thanks for any advice you can give, and sorry for the dumb questions!
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Welcome. First, I don't use XM so I wont comment on that.
    Your second question you need to consider yourself. How do you want it installed? Do you want everything to fit inside your dash, under your seats, in your trunk... How much room do you have? What type of pc are your planning on using?
    Third, it is not hard to learn to install a pc in a car. You don't need to know much about the inner workings of a car's electronics to do so.
    Lastly, this interface you refer too is called a front end. There are many available for you to choose from. There is an entire section on this forum just for front ends. I suggest reading through those posts and picking one. Then after you get your pc installed, you can worry about writing your own program.
    P.S. You should read through more of these forums before posting such open ended questions. Check out the show off your project section for install ideas.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Dawgy View Post
    You buy either a XMDirect or the XMDirect 2.... then buy the cables from Mitch. It can then be controlled with the PC via his software, or a front end like Centrafuse or Road Runner. Installing the PC is all up to you, your imagination, time, money and look. The electronics aspect in a car is much easier then home. 12V+ from battery via amp kit. then ground to the body of the car, cant get more simple then that.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  1. im confused with power supplies now :(
    By flavor4real in forum Power Supplies
    Last Post: 10-25-2006, 12:38 PM
  2. Should I change or Let her go?....So Confused
    By BIzFlawless in forum Off Topic
    Last Post: 05-26-2006, 10:27 PM
  3. xenarc came today... confused
    By chrislloyd in forum LCD/Display
    Last Post: 04-04-2005, 09:01 PM
  4. Confused About This
    By infintyinf in forum Newbie
    Last Post: 03-01-2004, 03:17 PM
  5. Im confused...
    By gsand in forum Software & Software Development
    Last Post: 10-07-2003, 08:10 PM
