Results 1 to 2 of 2
Thread: USB Hub
    Jul 2008
    USB Hub
    Hi,
    My question is simple, I'll have around 10 things to plug to my computer using USB. So I'll need at least 1 USB Hub. I have seen that some of you were using "powered" USB port and was wondering if it was necessary? or I can use a regular one?
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Cool 5v line?
    I run my 8" lilly & a Belkin 4 port hub off my M4-ATX. A powered hub will take the load off your MB. Most ports are rated at 500ma (I think) each. A 4 port UNpowered with 3 things plugged in (200ma each=600ma) and you've got problems. You will have things turning on and off at random. I would highly recommend a powered hub.
  1. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 04:42 PM
  2. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  5. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 12:38 PM
