Some of these have menu options that can be changed. Does the amp not power on when you switch it or are you not getting audio through to your amp? If it is not powering on, wire the remote wire to a constant power source and see if you get audio that way. If you do, run a power wire to a switch and then to your amp. Then just hit the switch when you want the amp to power on.
LinkBack URL
About LinkBacks
