Results 1 to 2 of 2
Thread: Help with soldering and expoying wiring harness
    Dec 2005
    I need to make a custom wiring harness connector to be able to easily swap my stock hazard switch with the one that works with my dash insert. If you're curious about why, etc., check out my thread:
    Help building a wiring harness adapter to use 98 hazard switch in 01 Accord.
    Anyway, here's what a rough mockup looks like:
    The white connector coming out of the dash is the stock connector. I've poked the wires into it as a test and it's just hanging there. What I want to do is solder those wires (the ones poked into the stock connector) to this (top right item):
    That's a spare hazard switch, taken apart. I'm going to just solder the wires onto that piece. That will give me a nice adapter harness so I can switch back and forth if needed (again, see original thread above if interested).
    My Question: Why kind of goop can I pour into the soldered piece to fill in the gaps and insulate and protect everything? Bonus question: any special kind of solder or soldering techniques I should use (I've soldered very few wires and things in my life).
    Dec 2005
    Here's a better visual view of what I'm going to do:
    I'm going to solder the bare wires to the exposed contacts (approximately where they're laying)
    Here's another view of the connector I'm going to solder to:
    The orange lines show the continuity of the connectors - I could solder to either side of those.
