Results 1 to 10 of 16
Thread: Can i Use any MotherBoard??
    Oct 2008
    Hello, i am a little new to the carpc scene but i know about computers and how they work etc. My Question is i see alot of people use the mini-ITX MOBO.... in just about all their installs well, i wanted to know if i can use a regular motherboard... i have a extra one just sittin here collecting dust and i know it works i just dont want it to go to waste..... i am not really picky about the space it will take up... but if i can use it what kind of PWS Can i use (recommended) etc. Thanks any help or responces will help greatly.....
    Feb 2006
    Melbourne, Australia
    What brand/model board? What cpu's are compatible with it?
    Let's see if we can help after you share that info
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Oct 2008
    well its an amptron (i think) its a 1.1 ghz cpu with 1 gig of ram its an old mobo like 2000 model...... its still good for what i plan to use it for ( mp3,dvd,gps,etc)
    Oct 2008
    I remembered what kind of motherboard i have the model number is syntax 740mp...... i was reading the forum about the m4 psu and i think this will work but can i get that confirmed
    Elsewhere
    Quote Originally Posted by MGMCarPC97 View Post
    Yes. You're only limited by three factors:
    Physical space
    Power consumption
    Heat
    Can't recommend an power suply unless we know more about the board. Is it ATX compliant? If so, there are several ATX-compliant DC-DC power supplies that would likely do you well.
    How about the Wiki?
    Oct 2008
    How can i find out if it is atx compliant??
    Oct 2008
    also if it is atx compliant what kind of wattage do i need to power the carpc up
    for example: 80watt or 320 watts psu?
    Newbie freak3dot's Avatar
    Mar 2006
    Indianapolis
    I found this calculator helpful in picking out my power supply:
    http://carpc.kyferez.com/Tools/PSUWattageCalculator.php
    Like DarquePervert said above,
    Physical space
    Power consumption
    Heat
    The mini-ITX boards are for people that are limited by space.
    The calculator above will help you determine if you are limited by power consumption. You should also know that more power consumption means a bigger power supply and more money.
    If you are limited by heat, then you will probably want to add more fans, vent holes, or find a cooler spot for the pc.
    freak3dot - Computer Science Degree
    1994 Chevy Cavalier
    Phase 1 parts purchased.
    Oct 2008
    okay thanks Freak3dot i looked at it and it told me "Your Recommended Minimum Power Supply is Watts Peak !!* " with that in play that can give me an i idea at what i am looking for but i still a regular full-size atx motherboard?
    Mar 2006
    Indianapolis
    You can use a full size atx motherboard if space isn't a problem.
    I was planning on using a full size atx motherboard since I have one to spare. I'll let you know how it turns out. I should have updates sometime in the next month.
    1994 Chevy Cavalier
  1. MTB-057 Intel D945GCLF Mini-ITX Motherboard OS Installation problems
    By Fiberoptic in forum MP3Car Products - store.mp3car.com
    Last Post: 07-08-2008, 01:50 PM
  2. Start problem with new jetway 7F2WE motherboard
    By superkenel in forum General Hardware Discussion
    Last Post: 08-03-2007, 06:06 AM
  3. Still Can't Get New Motherboard To Power Up
    By james33440 in forum General Hardware Discussion
    Last Post: 10-22-2005, 12:02 AM
  4. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 12:00 AM
  5. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 04:38 PM
