Results 1 to 5 of 5
Thread: Need Help on Installing Audio Capacitor
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    I bought a used 1.5 Farad Audio Capacitor off of Craigslist, and it didnt come with any instructions. I have never installed a Audio Cap before, so I have no clue what I'm doing
    I have three leads on the top, + (positive) - (negative) and then theres just a screw, which does something, but it isnt marked. Any clue what this is for?
    I would assume to install the cap, I would put it inline with an amp on the +12v line, and just ground the other side. Yes?
    TIA
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    May 2006
    Calgary, Alberta
    Step 1 - firmly grasp your capacitor with both hands
    Step 2 - open your trash bin nice and wide
    Step 3 - throw it in
    It's cause and effect. I'm guessing you're noticing a strain on your car's electrical system with your current install so you're getting a capacitor to try and offset this. The capacitor is simply making sure there's reserve power for the electrical components, your car is still feeling the same strain. Eventually you're going to kill your battery or set your car on fire. Throw it away.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Nov 2008
    Quote Originally Posted by Maheriano View Post
    exactly what he said!
    throw it in the bin! they cause mad strain on your car and do not do much good.
    If you are experiancing strain on your car (lights flickering) then just uprate your batterys wires to allow for better flow, like your ground from ur engine to your battery, the altornator wire to your battery, and your mains wire. uprate these to 0 Gauge wire!
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    if you want to stabilize the power in your trailblazer, I would seriously do away with your 600watt XOVision Power Inverter, the 300watt Standard ATX Power Supply, then put an opus DCX6.250 to power your computer.
    Right now you are taking 12 volts DC and converting it to 120 Volts AC, only to bring it back to 12DC simply to run the car computer.
    That wasted energy causes unnecessary heat in your car, not to mention adding wear and tear on your vehicle's alternator and electrical system.
    Like the guys above me mentioned, find the nearest trash can to dispose of that capacitor. No hard feelings, but they're right.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Audio Interrupt "Black Box" for Stock Head Unit
    By jmciver in forum Hardware Development
    Last Post: 10-11-2007, 03:15 PM
  3. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  4. Installing a computer as a audio source
    By jorge060801 in forum General Hardware Discussion
    Last Post: 12-01-2005, 03:43 AM
  5. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
