Hey, after a few more days of reading I have come up with a different computer then what I first had. The specs for this one is as follows.
Intel BLKD945GCLF2 Mini-ITX Motherboard with Integrated Atom™ Processor
M2-ATX-HV 160W Intelligent DC-DC PSU
BU-353 Weather-proof GPS Receiver
iGuidance v2009 4.1 Laptop, UMPC/Car PC Edition
Roadrunner Front end
Western Digital Caviar Blue WD800JD 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s
LG Black 20X DVD+R 2MB Cache SATA 20X DVD±R DVD Burner
StarTech 6" 20 pin ATX Power Supply to 24 pin Motherboard Adapter
Nippon Labs 4-Pin PC power to 2 x SATA Converter Cables Model POW-SATA-2
Link Depot 4 Pin Power Y Cable Model POW-ADT-4PY (Just in case)
BYTECC 18" Serial ATA-150/300 Cable w/Locking Latch Model SATA-118C X2
WINTEC AMPO 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300)
Creative Sound Blaster Audigy SE SB0570LPVP 5.1 Channels 24-bit 96KHz
Lilliput 629 7" VGA Touchscreen 629GL-70NP LED Backlight
Windows XP (with Nlite if I can figure it out)
All the amps and speakers haven't changed
As far as the wiring goes, I plan on using 2guage wire from the battery with a 150amp inline fuse running to a distributer block that will go to the M2 ATX by a 8guage wire that has a 15 amp fuse in the block and also to my amps with a 4guage wire that has a 90amp fuse. The M2 ATX will power my Lilliput monitor along with the DVD/CD rom, 80GB HD and the PC. The 4guage wire that is going to the amps will run into another distributing block that will split it into 2 8guage wires, one will have a 60amp fuse that goes to the MPR-M500 (sub amp) while the other 8guage wire will have a 30amp fuse and will go to the MPR-F250 (4channel amp) The brown wire that is connecting the two amps together is suppose to be the remote wire for the amps. I don't like lines over lapping in wire diagrams so I had to put it like that. When I install it, I will be splicing 1 of the remote wires into the other so I will have 1 wire going to the M2 ATX for the "anti thump"
Hopefully everyone can understand my wire diagram. If anyone spots any problems can you mind telling me? I want to play with wires only 1 time if you know what I mean.
In the preview post option it looks like the image has lines missing, however if you click it and let it load to the bigger size, all the lines are present.
LinkBack URL
About LinkBacks
