Results 1 to 7 of 7
Thread: Need to power a PATA hard drive. That's it.
    Nov 2008
    Hi all. New to the forum. I have a 99 CRV and I want to stash a PATA hard drive in the lower console (the one that swings down) for MP3's. My stereo head unit has a USB port in the front in which I'll plug into. Nothing fancy here, except I want to know what's the best way to power the hard drive.
    I have an HD enclosure that'll take normal AC voltage. Should I take it apart (nice because I can mount it to an HD bracket that's mounted to the lower console) and use a small DC to DC ATX PSU ($30 or so) using only the PATA connectors to power it? Or should I just get an inverter ($30 or so, can get at Home depot) and reroute my cigarette lighter down there?
    Jan 2008
    Quote Originally Posted by ruckerz View Post
    i would go for dc-dc convertor and a atx turning on thing shorts out pins 14 and 15 i think
    Elsewhere
    Check the output on the AC adapter. It's probably 12vDC, but could be some other voltage.
    If it outputs 12vDC then you can, as coreyspeed suggested, use a 12v regulator (not a converter, since there's nothing to convert) such as a Carnetix P1260, which is not manufactured any longer.
    There used to be 12vDC regulators available through thge mp3car.com store, but they aren't there any more...
    Mpegbox.com has them. Check the DSX12V or DSX12VD.
    How about the Wiki?
    Nov 2008
    Quote Originally Posted by DarquePervert View Post
    Unfortunately the hard drive needs +12v/+5v (standard PATA), then I would probably have to get a power supply say the DSATX? Any ideas on price on this ? Can I hook it up directly to my car battery (i.e. does it act as a regulator?). I was looking at the picoPSU-90 (less overkill on power needs), but it needs regulated power as input.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    There used to be 12vDC regulators available through the mp3car.com store, but they aren't there any more...
    the Opus DCL11 is still available in the MP3car store, but it's 1.3A@12v output may not be enough for a 3.5" HDD
    Elsewhere
    Actually, a Carnetix model with a 12v primary and 5v secondary would better suit your needs. I think the P1290 is right up your alley.
    The DSATX is an full-on ATX-compliant PSU, meant to be a direct replacement for a desktop PSU. It could be made to work, but it's a kluugey solution, at best.
    Quote Originally Posted by FusionFanatic View Post
    I didn't realize those could output 12v. I learned something new.
    However, it's not going to work, since the OP needs both 12v and 5v.
    How about the Wiki?
    Nov 2008
    Seems as if the P1290 has been discontinued. Also I've noticed that many of the solutions are in excess of $50 USD. The A/C adapter on the USB external case asks for 110V A/C @ 1A so according to my calculations... (2 A * 12 V = 24 watt) assuming 50% loss in the conversion. Wouldn't a 100 watt cigarette lighter power inverter for $20 from walmart make more sense?
    I don't need any fancy features such as power monitoring, ability to survive car starting, etc. It's just a hard drive and I plan to turn it on only when I'm going to use it.
  1. Add an Extra Hard Drive
    By joesan in forum MacCar
    Last Post: 05-16-2007, 10:35 AM
  2. Carnetix p1900 and Travla c138 120watt?
    By john_draws in forum Power Supplies
    Last Post: 05-27-2005, 12:42 AM
  3. USB hard drive and hibernation
    By Chairboy in forum General Hardware Discussion
    Last Post: 11-12-2004, 04:39 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  5. Power Supply Electromagnet + hard drive = :X ?
    By egeekial in forum General Hardware Discussion
    Last Post: 08-09-2004, 09:47 PM
