Results 1 to 4 of 4
Thread: installing software without dvd drive
    Nov 2005
    okay so i managed to break my dvd drive while doing my car install and i havent bought another one, but i want to install ms streets and trips 07 so i have gps in my car, is there a way to put it on a flash drive so i can install it from there?
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Yep, just copy the entire contents of the disc to a folder in your flash drive, then run the setup.
    Nov 2005
    yea i tried to do that but there was an error, maybe the flash drive i used wasnt big enough? I will try again tomorrow.
    Apr 2006
    Greensboro, NC
    You could place the cd-rom in another machine and enable file sharing on the cd-rom device and install it via your local area network connection. You could use an ISO image utility such as UltraISO to create an image of the disc. You could then copy the ISO file to your machine via usb, network, etc. You then mount the image with a utility such as Daemon Tools or VirtualCDRom.
    VIA Epia M10000 MB
    512 DDR RAM
    40G 2.5 HDD
    SP7 7" VGA TS dash
    Lilliput 7" RCA rear
    Holux GM-210 GPS
    Linksys WUSB54G
    Mini-Key USB KB
    CarPCSub 0.71 Win32 + 0.71L Linux
    GPS to Subtitles Recorder
  1. FAQ: How to install a DVD R/RW in your Xenarc 700IDT
    By cdcamaro9534 in forum The FAQ Emporium
    Last Post: 12-10-2007, 12:34 PM
  2. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 04:06 PM
  3. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 12:16 AM
  4. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 07:06 PM
