On the power wire going from the Distro block, i would use 10-8awg over 12.
Okay, so I'm almost out of the research phase. I think I got everything down...
The computer will be mo-co-so's 1.6GHz Intel Atom Dual Core pre-built PC, with M2-ATX power supply built in. I find it to be the easiest and cheapest route for me, as I'm in college and plan on spending as little time and money as possible, and get this thing up and running.
The LCD's a Lilliput 629 (2008 model) and will be installed into the car via the Mechatroniks double-din kit. Behind it will hold the PAC SWI-X and the IR receiver. In the pocket below the climate control is the supplied CD-RW/DVD Drive and a 7-port USB hub.
Haven't decided on the amp yet. Gotta still figure out what route i'm gonna go with for audio.
It's still a work in progress, but I think I've got the whole wiring aspect down. I'd like feedback on my wiring diagram below. All suggestions and comments are very much appreciated.
Thanks for reading!![]()
My First CarputerIf its not broke, try and fix it.
