Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Newbie Starting Carpc For First Time
    Dec 2008
    Hello. I recently got my carpc and I am starting to bench test everything. I connected the monitor to the pc and booted it up. The first screen says "HP INVENT" with 2 options:
    F8 - Configuration and Diagnostics
    F12 - Boot on LAN
    So I hit F8 to go through the configuration process. When I get to the next screen, it states:
    Boot Devices
    CD-ROM
    HP Diagnostics
    I am lost once I get to this screen. What am I supposed to do from here? Is anyone willing to walk me step-by-step through this whole process in order to get me to the main desktop screen?
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by bassboy3313 View Post
    F12 - Boot on LAN
    Boot Devices
    CD-ROM
    HP Diagnostics
    When installing Windows, one would typically boot the computer with a cd rom. If that's not what you want to do right now, then change your settings to boot from a hard disk.
    Dec 2008
    how do you change the settings to boot from a hard disk?
    Oct 2007
    You'd want to change that setting in your BIOS.
    BIOS stands for basic input/output system. Often referred to as CMOS, the BIOS provides an interface for a computer's hardware and software. The BIOS configuration determines how your hardware is accessed. However, not all computers pull up the BIOS Configuration Setup Utility using the same key.
    On mine, I'd reset the computer using the reset switch, and during the first ten seconds of restart I tap on the "Delete" key till it gets me into the BIOS configuration. See if your puter works the same way, and go from there.
    Dec 2008
    ok. i will try that first thing tomorrow. if you are able to give me a DIY kind of thing to get my puter up and running I would GREATLY appreciate it.
    Oct 2007
    get into your BIOS first, read the navigation KEY at bottom of the page to learn how to change the settings, and save them before you exit. Once there, it is somewhat self explanatory.
    If you still have trouble, post back.
    Dec 2008
    wut should the sequence be then? will i need a windows xp cd or anything?
    Oct 2007
    hard disk first, anything thereafter doesn't matter. You can disable the rest or select what you desire to come on after the hard drive.
    Dec 2008
    Oct 2007
    it seems like there's an operating system on it already, therefore you don't need one. Otherwise, you should have your HP disks available when doing so, and instead boot from the cd-rom to install the OS that came with your system.
  1. Replies: 2
    Last Post: 01-31-2008, 03:15 AM
  2. Newbie CarPC equipment list review
    By e30sleeper in forum Newbie
    Last Post: 01-24-2007, 01:01 PM
  3. Newbie to carpc!
    By joe_c in forum Newbie
    Last Post: 12-07-2006, 11:39 PM
  4. Newbie Questions for a 2nd Time!
    By Sound of Silenc in forum Newbie
    Last Post: 03-10-2005, 04:37 PM
  5. Newbie and his CarPC
    By madfish in forum Newbie
    Last Post: 02-12-2005, 04:00 AM
