Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Touchscreen help!
  1. #11
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    You may want to reboot a few times before you celebrate.
  2. #12
    Oct 2006
    have done now, still seems ok, also now tried on my desktop pc and the in car pc
  3. #13
    Oct 2006
    seems to have gone wrong again! in the same way. Afte many boots its just reverted!
    The only thing that had changed was that i plugged in my TOMTOM to charge from the pc (via USB), then turned the pc on and the touchscreen was doing its old problems^^.
    Don't know if this is coincidence or not but any ideas people!
    thanks
  4. #14
    Oct 2006
    anyone else had this problem? thanks!
  5. #15
    Mar 2006
    Colorado, but Canadian!
    I think the drivers are merely a coincidense. There is something on your screen pressing against the case. Could be you molded it crooked, or could just be dust. Take a credit card and slide around the edge of your screen carefully.
    Other option is the controller is dying and it wont store calibration settings. Then it would work after calibration but slowly go away. Depending on how much time between it working and not working this might be it too.
    Solution A is easy, B means you need a new touchscreen controller or overlay.
    1.9in x 2.9in -- 47mm x 73mm
  6. #16
    Oct 2006
    i have already tried taking the case apart before, what i can't understand is that i have the screen working for over a week before it messed up again :S
  7. #17
    Oct 2006
    anyone!
  8. #18
    Oct 2006
    bump
  1. 2006 Acura TL OEM Navi Touchscreen Integration
    By met152 in forum Show off your project
    Last Post: 09-24-2010, 10:34 PM
  2. Replies: 2
    Last Post: 03-27-2007, 04:28 PM
  3. Problem Identifying Touchscreen Controller
    By yingyang006 in forum Input Devices
    Last Post: 01-08-2007, 09:01 PM
  4. Replies: 4
    Last Post: 10-13-2004, 09:17 AM
  5. USB Touchscreen Problem
    By skeeter007 in forum Input Devices
    Last Post: 10-07-2004, 02:49 PM
