Results 1 to 4 of 4
Thread: Fans Run, No beep
    Dec 2008
    Fans Run, No beep
    Opus 120w Powersupply
    ITX Mobo 1.8ghz
    When the ignition is turned, the power supply kicks an and the fans start to run but the system doesn't beep like it's booting and I get no input on my screen. On AC power it runs fine. I think I've narrowed it down to switch connection. I have tried different ACPI settings in the bios to no avail. the OPUS is switching on power but I'm getting no lights at the front panel like on AC power. Am I missing something?
    Newbie Tumeski's Avatar
    Nov 2006
    Pieksämäki, Finland
    Lets clear this up. When you take the computer to normal power and plug it in PC boots nicely and works as supposed to?
    If you then move it to your car and plug it in, it doesn't boot up anymore?
    Well i'd say that check all the power wiring first, try basic setup dont plug devices in, use just the basics and screen and try to get image first and so on...
    Dec 2008
    That is exactly right. Now I'm thinking that my battery may be a little flat and causing some issues. I'm just using an older needle display multimeter but I'm only getting about 10.5ishv at the Opus. The car hasn't been run in the snow yet so this is understandable. Thanks for the reply!
    Nov 2006
    Pieksämäki, Finland
    Well yeah, its a good idea to recharge the battery it will take some issues down.
  1. Want to run house on server.
    By Maheriano in forum Off Topic
    Last Post: 01-20-2008, 02:05 PM
  2. Controlling Fans
    By pshadwick in forum General Hardware Discussion
    Last Post: 06-25-2007, 05:45 PM
  3. UPS run from inverter?
    By FyreDaug in forum Power Supplies
    Last Post: 01-18-2007, 07:03 PM
  4. Adding extra fans to Opus Mini PC Case
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 09-26-2005, 11:52 PM
  5. Installing Fans
    By DoDaDDy in forum Input Devices
    Last Post: 11-29-2004, 08:14 PM
