Results 1 to 10 of 17
Thread: Carputer Key?!
    Dec 2008
    Carputer Key?!
    At the rear of my Carputer there is a key hole and I do not have the key, is this to stop you from being able to open up the pc?
    can I 'bust' it off?
    Dec 2008
    the black circle on the rear
    Aug 2008
    Guam
    Do you have any bigger pictures?
    I remember way back that there was a key to turn on the 'turbo' function of desktops. If it's a newer computer, then I'm sure it's probably to keep the case locked. I know we have that on our servers.
    Sep 2007
    Raleigh, NC
    My bet would be that it is intended to prevent the case from being opened. Like rat, we use them on our machines at the office.
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    a larger photo would help us determine what it's intended for.
    Jan 2008
    i think this is the computer he has, it is from ebay.
    http://shop.ebay.co.uk/merchant/cube...Q_fromZQQ_mdoZ
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    If that's the same case, then the black thing is a lock. See the locked padlock symbol to the left of the black knob.
    Constant Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    I would suggest just trying to pull the case apart after removing the two side screws an see if you can at least look inside.
    If they did supply a item like that without the key, I would be contacting the supplier and demanding the key. Otherwise remove the lock and then put something useful there
    2004 Holden WL Caprice Auto GENIII
    Base PC = Installed
    Front End = In Progress 75%
    OBD2 Interface = Installed / V2 Due Soon
    Realworld Interfaces = In Progress 20%
    Internet Linking = In Progress 10%
    Voice Control = In Progress 35%
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. Carputer Shock Absorber
    By bcholagh in forum General MP3Car Discussion
    Last Post: 08-09-2005, 12:09 AM
  3. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
  4. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  5. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
