Results 1 to 6 of 6
Thread: Question about a possible Monitor
    Jan 2009
    I just recently bought a new touch-screen stereo for my car. I was wondering if anyone knew if it would be able to be used as a monitor as well as the stereo system.
    It is a Pioneer AVH-p4000DVD A/V receiver. http://www.pioneerelectronics.com/PU...P4000DVD?tab=A.
    I wasn't sure whether or not a cable could be run from the computer to this touch-screen.
    Thanks much!
    Newbie miko55's Avatar
    Jun 2007
    Ljubljana, Slovenia, Europe
    I think you can ,due to spec.
    Composite A/V Input 1 (AV1)
    Source
    Marked witd red color is S-video input, if I am correct.
    Slovenia, Europe
    best on-line radio
    Jan 2009
    Thanks for the help!
    Does that mean I'd use a cable that has the VGA at one end and a A/V connector at the other? Or does that mean I'd use a single cable with two A/V connectors?
    Also, I had read somewhere that using A/V won't allow you to use the touch screen, any thoughts on that?
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    no touch control read my other threat to get touch usb. also thats not a s-video input, it's RCA. pretty sure there's no VGA to RCA cable.; your only solution is PC with RCA video out or S-Video out with a a S-video to RCA converter cable bought only online.. not very common...hard to find.
    Did it.. Done it... now I got to keep the neighbors kids away!!
    Aug 2008
    Dec 2008
    Reuse existing LCD panel in a dvd player
    Hi
    I am also thinking of using the double din dvd players LCD touch panel as a screen.
    I am planning to remove everything except amplifiers, LCD, then going to place a psu and PICO itx board.
    By this way is it possible to re use the existing LCD TOuch panel.
    Since the case and motorized LCD is available i dont need to much worry about the case and monitor.
    The HU i am going to use:
    PIONEER DOUBLE DIN AVIC-HRZ88
    please some one help me
    thanks
  1. Multiple Monitor Question
    By qasim in forum LCD/Display
    Last Post: 05-16-2007, 07:08 PM
  2. Dual Monitor question
    By DjBac in forum Fabrication
    Last Post: 08-21-2004, 05:05 PM
  3. Monitor Power Question - Is this a danger?
    By Sivion in forum LCD/Display
    Last Post: 07-28-2004, 06:46 PM
  4. Question about Lilliput Monitor.
    By SwapMeet in forum Newbie
    Last Post: 07-19-2004, 02:06 AM
  5. LCD monitor question.
    By Dex4now in forum LCD/Display
    Last Post: 12-07-2002, 06:46 PM
