you're confusing two different PSUs. the M2-ATX can output 160w, the M2-ATX-HV can output 140w (1A less on the +12v rail). either one should work fine for the D201GLY2.
great GPS receiver. I use the same one myself
that should work fine. you could also consider getting the Visteon HDZ300 with Mitch's PC cable. this will allow you to listen and control AM/FM and HD radio through your PC. I bought a used HDZ300 on eBay for $30 (it doesn't matter how it looks because the unit itself will be hidden, with Mitch's cable you control everything through the PC. RoadRunner has a HD tuner screen built-in)
that's a nice monitor for the price, but the $50 extra may be worth it for the 629 instead. it is LED backlit with a much higher contrast ratio. this will make it more usable in sunlight.
[quote=fish;1283041MOBO - Intel D201GLY2 Little Valley with 1.33 GHz Celeron Processor (or somehthing similar)[/quote]
great little board. I use the D201GLY2A (fan-cooled). you could also consider the new Intel "Little Falls" boards with the new dual core ATOM processors. I have no experience with them but they seem to be pretty popular lately.
RR is great, and DFX4 is an awesome skin. best RR skin out there IMO
that's up to you. both have their pro's and con's. as somebody who has used both, I personally prefer the Mini-ITX system over a laptop install.
if you're willing to spend the money on a mac-min, then go for it. the mini is not that much smaller then a mini-ITX system, but if you're very tight on space then saving those extra couple inches might be worth the extra cost.
personally I have never understood why anybody would spend the money on overpriced mac hardware, only to put Windows on it. the MacOS is a mac's strength, if you're not going to use MacOS, then why pay more for the hardware?
this question has come up many times here. some say laptop drives are better, others say desktop drives are better. they both seem to do just fine. I have used laptop drives in both my CarPC's and never had a problem with them. there are plenty of members here who have used desktop drives no issues as well.
potholes have the potential to damage any mechanical harddrive (both desktop and laptop). if you're worried about it then get a solid-state drive (they aren't cheap).
it wouldn't be too hard to make a slide out bracket with a hinge at the end. you would have to find a way to secure the monitor in the upright position.
why does it need to slide out? are you keeping a head unit? what kind of car are you putting this in?
LinkBack URL
About LinkBacks
