is that computer complete if i do my own case ?
( do not chek if i have all rhe option ...just chek if everything will work :P)
1.motherboard
D945GCLF2 "Little Falls 2" Mini ITX Motherboard by Intel
Intel has done it again with the release of the D945GCLF2. Packing it with the new ultra efficient 8 Watt 1.6 GHz Dual Core ATOM 330 CPU, GMA 950 graphics, S-Video output, and a total of 8 USB 2.0 ports. It also features support for up to 2GB of DDR2 533Mhz or 667MHz of RAM, SATA 2.0/3.0Mbps connectors, and high definition audio, for under $100, making it an ideal choice for embedded, automotive, HTPC applications. The D945GCLF2 will also have a 24 month life cycle making it suitable for some industrial applications.
Product Specifications
Processor ATOM 330 1.6GHz Dual Core 8 Watt CPU with 1Mb L2 cache
Front Side Bus 533MHz
Chipsets Intel 945GC Northbridge
ICH7 South bridge
Graphics Intel GMA 950
System Memory 1x 240 pin DIMM socket for DDR2 533MHz/667MHz RAM
Supports up to 2Gb
IDE 1x ATX 100
SATA 2x SATA 2.0 (3.0Mbps)
USB 8 total USB 2.0 ports 4x Rear Panel / 4x internal headers
LAN 1x 10/100/1000 Mbps
Expansion Slots 1x 32 bit PCI
Audio Realtek ALC662 High Definition audio codec
Rear Panel I/O 2x Ps2 for mouse and keyboard
1x VGA
1x S-Video
1x 10/100 LAN
1x RS 232 COM
1x Parallel Port
4x USB 2.0 ports
3x Audio: Line in, Line out, and Mic in
Onboard I/O 4x USB 2.0 ports via pin headers
1x Front panel audio header
1x P4 CPU power connector
1x 20 pin ATX
1x Fan header
1x PCI slot
BIOS Intel BIOS 4mb flash memory
Monitoring and Management Power Management (Supports S3 standby)
Fan Speed Control
Wake on USB
Wake on PCI
Wake on LAN
Wake on Keyboard
Wake on Mouse
Operating temperature 0°C - 50°C
Form Factor Mini ITX 17cm x 17cm
Also Included 1x IDE Cable
1x Driver CD
1x SATA Cable
1x I/O Shield/Back Plate
1x Quick Reference Guide
Details
Model: MCS-INT-LF2
10 Units in Stock
Customers who bought this product also purchased...
Lilliput EBY-701 Transflective Touch Screen Monitor
M3-ATX Automotive PICO Power Supply
Kingston 2G 667MHz DDR2 Memory Module
USB SiRF III GPS Receiver
HD Radio PC Interface
External USB Slot Loading DVD R/RW Drive
Reviews
larger image
Intel D945GCLF2 Little Falls 2 Mini ITX Motherboard
[MCS-INT-LF2]MCS-INT-LF2
$84.39
2.usb dvd drive slim
Mobile Computing Solutions designed these drives to include space saving slot loaders in external notebook combo drives. Perfect for use in a Car PC system since they can be powered exclusively by USB 2.0 connection. Their small foot print and trayless design make them ideal for use anywhere space is limited. If need be, they can be mounted vertically, horizontally, sideways, or even upside down. No matter what your use is, if you need to add an external DVD/CD-R/RW drive to your system this is the way to do it.
Features:
Compact size and sleek trayless design
DVD player and CD reader/writer
No external power adapters required
Includes USB patch cable and PS2 power pass through cable for USB 1.1 ports
Plug and play with XP based computers, includes drivers for non-XP machines
Full retail packaging and one year warranty
Details
Model: MCS-CMBO
Shipping Weight: 2lbs
107 Units in Stock
PICOPSU120 12V 120W DC-DC Mini ITX Power Supply
AC-DC 12V / 5A Switching Power Adapter
USB External Notebook DVD/CD Drive case
Intel D945GCLF Little Falls/ATOM Mini ITX Motherboard
6 Pin 16AWG Wiring Harness
M4-ATX 250W 6-30V DC-DC Power Supply
Reviews
larger image
External USB Slot Loading DVD Combo Drive
[MCS-CMBO]MCS-CMBO
$64.99
3. rAM
Kingston's high quality low cost generic RAM is perfect for building your own system or replacing parts in an existing system. Comes with a standard lifetime limited warranty.
Technical Info
Manufactured by Kingston Technology
Manufacturer Part Number KVR667D2N5/2G
Memory Size 2G
Memory Type DDR2 SDRAM
Memory Speed 667MHz
Form Factor 240-pin
Unbuffered
Non ECC
Warranty Standard Warranty Lifetime Limited
4.M2-ATX is an intelligent, high power 12V DC-DC ATX PC power supply for car PC and battery powered applications. Designed to provide power and to control the ON/OFF switch of a motherboard, based on ignition status, battery voltage, or time. The M2-ATX has a wide voltage input of 6 to 24V and it is capable of surviving tough car engine cranks as well as transient over-voltage situations.
M2-ATX has eight user selectable microcontroller driven timing modes, allowing you to choose up to eight ignition/shutdown car PC timing schemes via a built-in shutdown controller. By removing all user-selectable jumpers, M2-ATX becomes a traditional PC PSU with no ignition control (shutdown controller bypassed) and it can be used in non-vehicle computer applications.
Even if your computer is totally off, a PC will still consume a few hundred milliwatts, which is needed to monitor PC ON/OFF status. When the computer is in the sleep mode, it will consume even more power, because the RAM needs to be powered at all times. The power consumption in the sleep mode is few watts. No matter how big your car battery is, it will eventually be drained by the computer.
While in sleep mode, M2-ATX constantly monitors your car battery voltage levels, preventing deep discharge situations by automatically shutting down (using a built-in shutdown controller) until battery levels reach safe levels again. No more dead car batteries, no more computer resets during engine cranks, along with multiple timing schemes, small form factor and very competitive price makes the M2-ATX the premier solution for DC-DC ATX vehicle/car PC power supply solutions.
M2-ATX is compatible with all of our cases and with most Casetronics and Morex enclosures.
NOTE: M2-ATX provides up to 8A on the 12V rail, making it ideal for operating most P4, P4-M, Celeron, AMD systems. Low power Geode and VIA processors (C3, C7) will work as well, leaving ample power for 12V or 5V peripherals.
The M2-ATX comes with a complete set of cables including:
ATX cable extender with dual 3.5" HDD and one Floppy drive power (9")
Power input cable for ground, +12V, and +12V acc (12")
Two pin M/B on/off power ON control wire harness (9")
Set of black jumpers to control various power sequencing schemes
Features:
160 watts output
Ideal car Power supply for operating P4, P4-M, Celeron, AMD systems
ATX, 6-24V wide input range
Intelligent shutdown controller
ON/OFF motherboard control
Survives vehicle engine cranks
Battery deep discharge prevention
High efficiency, 160 watts output
"Anti-Thump" Amplifier remote control
15A automotive fuse (mini-blade)
VIA, P4 and AMD CPU support
5. SSD DRIVE 30 GO
Featuring new architecture, the Core Series SSD V2 will be available in up to a massive 250GB capacity and delivers enhanced speeds of up to 170 MB/s read and 98 MB/s write speeds with an improved seek time of less than 0.2-0.3ms, making the Core V2 significantly faster when it comes to both Read/Write and seek-time performance. The addition of a mini-USB port also makes it possible for customers in the field to update the Core V2’s firmware should new versions become available, to further enhance compatibility or performance with future platforms.
The OCZ Core Series V2 delivers additional performance and reliability of the latest SSDs at a 50% less price per gigabyte than other high speed offerings currently on the market. The Core Series is ideal for an energy-efficient mobile or a RAID configured desktop to provide blazing speeds and advanced access and seek times. Because SSD drives feature no moving parts, the Core Series V2 will keep your laptop or desktop environment cool and quiet and provide a durable alternative and superior shock resistance. With even greater capacities up to 250GB, Core Series V2 now offers sufficient storage for large media files.
Designed for ultimate reliability, Core V2 SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term
If you want the most accurate and virtually instantaneous satellite fix times, you should insist on SiRFstar III technology. The SiRF III architecture offers superior performance, achieving time-to-first-fix in as little as one second, with the ability to acquire signals down to -159 dBm. This makes real-time navigation practical, especially in indoor environments, urban canyons, and under dense foliage.
6. GPS
Unlike the lengthy sequential search process of traditional GPS architectures, the SiRFstar III architecture has the equivalent of more than 200,000 correlators and enables fast and deep GPS signal search capabilities that result in significant improvement over today's architectures that contain a few hundred to a few thousand correlators. Don't be fooled by technical terms and clearance prices - if you had old technology you would sell it cheap to get rid of it, too. We buy our SiRF III GPS receivers directly from the manufacturer and pass the savings on to you. You won't find a better GPS receiver for less money anywhere
7.LILIPUT TOUCH SCREEN
The new adjustable LED backlight design offers a brighter crisper picture with no warm up time, better performance in cold weather with a longer life and lower power consumption then the older CCFL backlight model. The upgraded 4 wire restive touch screen now has an anti glare coating** applied to it and works with the included stylus or your fingers. Our exclusive custom cut screen protector will keep the surface of your screen protected while further reducing sun glare at the same time. The updated firmware now allows the EBY-701 to be set for automatically turn on when power is applied to the monitor. Our simple 5 step instructions to do that can be found here.
Every EBY-701 includes the following accessories:
Our monitors feature the new Locking Connector Patch Cables
Included Stylus for easy use of the monitor
The monitor harness connects the monitor to the auxiliary A/V Inputs
The 12vDC Automotive Power Supply allows for easy use in the car
The Touch Screen Drivers work with Windows, Linux, and Mac
The stand allows for easy adjustment and simple mounting
Full Function Wireless Remote Control
The 120vAC adapter allows for home use
8. sound card auzen x-fr prule 7.1
http://www.auzentech.com/site/products/x-fi_prelude.php
9.obd2 interface
Based on standard Bluetooth technology, this totally wireless OBD and drivers allow you to run the included software on almost anything including PDA's, Linux, and Windows based PC's/Laptops, and works with ISO, KWP, SAE, and CAN protocols.
Features:
Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
Clear trouble codes and turn off the MIL or "Check Engine" light
Based on the ELM327 interface it supports most protocols including:
ISO 9141
KWP2000
SAE J1850 both VPW and PWM
CAN
Included drivers for
Palm and PDA's
Windows based Smartphones
Linux
Windows XP
Not Compatible with Vista
Display current sensor data and status for:
Engine RPM
Calculated Load Value
Coolant Temperature
Fuel System Status
Vehicle Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen sensor voltages/associated short term fuel trims
Fuel System Status
Fuel Pressure
Many others...
Free software includes the following program:
Vital Scan
link http://store.mo-co-so.com/index.php?main_page=product_info&cPath=31&products _id=31
me:
i think maybe a fan....some wires ...
i dont know if something is missing ...and if all will work with all of those things...do i have the right psu for all of this?
will my sound card fit on the pci of this motherboard?
feel free to say me if i need anything else!
thanks a lot!
