Results 1 to 4 of 4
Thread: Connecting a M3-ATX power supply to saturn ion 03
    Mar 2008
    Hello, I am good with electronics, but know nothing about cars. Where would I connect up the power and ignition wires from a M3-ATX power supply to a Saturn ion 03? I know there is a fuse panel just below the radio, would I somehow connect the power to a spare fuse?
    thanks
    Jul 2006
    seattle
    no. power should be connected directly to the battery.
    Run a big enough wire for your setup directly from the m3-atx to the battery.
    For ign, you can use any available.
    dsatx in voompc 2 case <HERE>
    Mar 2008
    The battery is in the trunk though, it would be much easier if there was some other wires I could run it off of
    Elsewhere
    So do you want it done easily, or do you want it done properly?
    You're "good with electronics". You should know the correct answer...
    How about the Wiki?
  1. atx POWER SUPPLY?
    By nickweb in forum Newbie
    Last Post: 09-26-2005, 05:39 AM
  2. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Very Small/Mini Power ATX Power Supply?
    By xBrady in forum Power Supplies
    Last Post: 06-20-2004, 07:22 PM
  5. ATX, ITX DC-DC Power Supply
    By Navigator_82 in forum Power Supplies
    Last Post: 03-14-2004, 11:26 AM
