Results 1 to 5 of 5
Thread: Newb. Bout to buy my hardware, give it a once over?
    Jan 2009
    I'm going to be building my first carputer... pretty excited as I've used MP3Car.com's forums several years back (maybe 7-8 years ago??) and MAN! has the page grown since I last visited!
    I've done some reading and feel pretty set on my hardware choices, I just wanted to see if anyone had any feed back on some of the options I'm choosing...
    __________________________________________________ _______________
    Intel BOXD945GCLF2 Atom 330 Intel 945GC Mini ITX Motherboard/CPU Combo - Retail
    Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner & Capture w/full DVR Functionality - Retail
    Kingston 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model KVR800D2/2GR - Retail
    SUPER TALENT MasterDrive OX FTM16GL25H 2.5" 16GB SATA II Internal solid state disk (SSD) - Retail
    Western Digital Scorpio WD3200BEVT 320GB 5400 RPM SATA 3.0Gb/s Notebook Hard Drive - OEM
    TRENDnet TBW-105UB USB 2.0 Compact Bluetooth Adapter - Retail
    Rosewill RNX-G1W USB 2.0 Wireless White Dongle with External 2dBi SMA Antenna - Retail
    Dynamix 7" 710 Widescreen Touch Screen Monitor
    BU-353 Weather-proof GPS Receiver
    (Still have yet to decide on what PSU)
    The items I'm curious about are the Pinnacle USB TV Tuner, I understand HDTV wont work while moving, what about Standard Def. TV? and the FM Tuner? will those work fine in motion?
    Would I bet better off buying a PCI TV/FM tuner and taking up the 1 PCI slot on the mobo?
    The Western Digi HDD, it's a laptop HDD, low spindle speed (mmm save that power) and it boasts SecurePark and ShockGaurd technology. Anyone use these drives in their setups? it will be my Media drive.
    The 16GB SSD drive will host my OS (TinyXP 09, MinLogin and EWF) as well as any other static data such as GPS Maps etc.
    Also, I don't anticipate doing much "war driving", although I'd still like my WiFi adapter to have a decent range, hence why I picked the Rosewill Wifi stick, with the 2dBi gain antenna... though it will be behind my dash and likely obstructed from doing anything worthwhile lol.
    Any tips or advice on the components chosen?
    Jan 2009
    Outside of just looking atthe list, I wouldn't mind some advice if I'm barking up the wrong tree with any of my components.
    I've surfed the Review forums and several others here.
    Am I on point.. or do any of the decives listed suck for carputer use?
    Jan 2009
    I'm new to this myself, but I think the spec sheet for that mobo states DDR2 533/667 are the only ones supported, so I believe you're going to need to step your ram down a notch or two. The board supports DDR2-667, but clocks it down to 533, from what I've read. Someone will correct me if I'm wrong
    FLAC WuNgUn's Avatar
    Sep 2007
    For PSU, I wouldn't skimp...I'd go for the OPUS 320.
    Also, why did you decide on the 5400RPM HDD? And SSD?
    Personally, I'd use a desktop drive and skip the solid state drive altogether.
    I dunno about the touch screen, but everything else looks pretty good...
    What are you going to do for audio? I can't say enough good things about the Asus Xonar, but you probably don't have a PCI slot, huh?
    Jan 2009
    Quote Originally Posted by stratosigma View Post
    Good call on the RAM, I didn't even pay attention to that... And typically I do lol. I just added "Customers also bought" RAM to my wish list. heh.
    Thanks! I'll hit that up again and go for the 533 sticks.
    As for the Choice of SSD and also a Laptop drive with Low RPM.
    I like the idea of a read only OS (TinyXP09, MinLogin, Locked down with EWF). And a secondary media drive, each independent of another. If I need to reinstall Windows, I don't have to worry about messing with the media drive and vice-versa.
    Hopefully since I'll be running EWF and will rarely turn on file writes to the SSD OS drive, I wont have to worry about reinstalling any time lol. (Also this mitigates fragmentation on that drive, read only.).. Also SSD, no spinup time. so its ready a hair faster to load your OS. Kinda like the CF boot setups every one did awhile back, cept now we are no longer limited to the speeds of the CF cards... We can hit SATA 2 speeds with no moving parts =)
    As for a 5400RPM drive, it's just reading mp3s, videos (most of that being buffered initially anyway) and the rare nav map. No need for a faster RPM drive that runs hotter and uses more power. ( and a drive that can also take longer to spin up to a higher RPM)
    A laptop drive because... well I going under the assumption they are alittle more rigid. I'd have to read the full specs of the WD drive I'm getting to be sure, but I did see the words SecurePark, and ShockGaurd in the description lol
    As for the sound, good idea... the board has an AC97 audio chip I believe, 6channel... but crap lol.
    I do have an open PCI slot since I'm using ALL USB addons. I have a couple old SB Live Gold cards sitting around that I had to ditch when I took my mediacenter to Vista then Win 7.
    The PC was going to go in my IS 300... but then...
    Ouch =/ ... I wasn't a fan of yellow any way...
    So now it's going in my Audi A6 quattro
    Been working on a CentraFuse skin for it
    Thanks!
  1. Do Not Buy From Autonode.com!! Scammers!!!!
    By Surferx14_2 in forum Off Topic
    Last Post: 11-03-2006, 11:53 PM
  2. Where to buy hardware in california?
    By phrozen in forum General Hardware Discussion
    Last Post: 02-12-2005, 03:14 PM
  3. Give me some hardware recommendations…
    By xcntrk75 in forum General Hardware Discussion
    Last Post: 01-13-2005, 10:30 PM
