Results 1 to 5 of 5
Thread: Building my first carputer for my Transam need some advice.
    Feb 2009
    Toronto Canada
    Hi Guys thanks for stopping in.
    Well finally after being a custom car stereo installer and having many gps aftermarket head units with gps Ive decided to do a more trick system in my old ride and bring it upto date. Ive started buying parts and need some clarification on things i dont quite understand yet.Here is what i have:
    Intel DG45FC mobo
    Intel E5300 2.6ghz dual core 2mb cache 800mhz fsb
    Kingston 2gb ddr2 sdram
    This is what I plan on getting still:
    Voompc-2 case
    m2-atx 160w power supply
    Also this is what i dont know for sure yet but with the specs given id like to add gps,wireless internet,backup camera and somehow a on/off and reset button if possible.
    Anyone have any ideas.its been a long time since i built a pc.Thanks in advance.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by 87Transam383 View Post
    Intel DG45FC mobo
    Voompc-2 case
    The GPS, and wireless internet would be through USB..... backup camera would connect to what ever screen you plan to use. Reset button would come from the MoBo.... On'Off would go from the PSU to the MoBo, but you can also connect a power button to the cables. If I am not mistaken the M2-ATX has a jumper port on it to add a switch. I cant recall since I use OPUS.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Feb 2009
    Toronto Canada
    Ok that makes sense.Where would I find the power and reset buttons with the right connectors to plug onto the motherboard and relocate them onto my dash somewhere.I dont quite know the names of the certain plug ends I need.
    Elsewhere
    The switches connect to the motherboard using a jumper-style connection.
    You can wire up pretty much any switch to a lead.
    Another option is to scavenge power & reset switches from an unused PC case. They will already have the leads you need.
    How about the Wiki?
    Oct 2008
    this here's what you needs. MotherBoard header extensions http://www.performance-pcs.com/catal...ducts_id=21385 or http://www.orbitmicro.com/global/sta...le-p-5688.html
    Cut off one of the ends and solder a longer wire to a button.
  1. so now i need a carputer..a little advice
    By bmoore09 in forum Newbie
    Last Post: 06-17-2007, 06:45 AM
  2. Replies: 11
    Last Post: 03-15-2007, 08:16 PM
  3. Replies: 3
    Last Post: 05-02-2006, 11:05 PM
  4. building carputer with xbox
    By mduck in forum General Hardware Discussion
    Last Post: 03-04-2004, 10:36 PM
  5. Requesting advice on anything Carputer related...
    By Raekwon in forum General Hardware Discussion
    Last Post: 04-05-2003, 12:23 PM
