Results 1 to 3 of 3
Thread: ignition wire for M2-ATX
    Nov 2008
    Houston, Tx
    Hey, will the M2-ATX turn on if the ignition wire is plugged into a 5V source? The reason why I ask is because I'm putting all three wires(ignition,12v power, ground) onto a molex connector so that I can easily take the computer out of the car and plug it into my workbench PSU. When it is inside the car the ignition wire will be plugged into the radio power wire. But when its on my workbench, I'm wondering if the 5V wire off of the workbench PSU will be enough.
    Nov 2008
    Houston, Tx
    Just tried this and the ignition wire needs a 12v source. However, I did get to keep the idea of using the molex connector. In order for this to work with the workbench PSU I had to cut the 5V wire and splice it into the 12V wire on the PSU side.
    FLAC WuNgUn's Avatar
    Sep 2007
    Or you could of just splice the IGN lead into any of the yellow molex wire??
    There is no real current draw on the IGN lead...
  1. M2-ATX won't turn on with ignition wire
    By apatheticfrimbo in forum Power Supplies
    Last Post: 10-11-2008, 09:03 PM
  2. Ignition Wire Help
    By Stang70Fastback in forum Power Supplies
    Last Post: 12-29-2007, 10:00 AM
  3. Power Source and Ignition wire ??
    By CoupeE46 in forum General Hardware Discussion
    Last Post: 02-05-2007, 01:42 PM
  4. Opus ignores ignition wire, constantly stays on
    By Sham-Mobile in forum Power Supplies
    Last Post: 08-26-2006, 07:28 PM
  5. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
