Most all 5.1 PC audio solutions will work for you...
Typically, the sub and center channels are both mono, so the sound card usually pairs this up on a single jack...
F/R will have their own stereo jacks...
If your into SQ, you will want something better than onboard sound...
Also, be aware of the software being used...your input will likely only be 2 channel (your not making a full, 5.1 setup in the car are you?), so the software has to be able to output that to all your channels.
Or you could go the CONSOLE or AudioMulch route and take CONTROL of your audio!![]()
LinkBack URL
About LinkBacks
