Results 1 to 5 of 5
Thread: OPUS DCX3.120 Help
    Dec 2008
    OPUS DCX3.120 Help
    i recently bought the OPUS 120 watt DC-DC power Supply DCX3.120 and got everything going for the most park. There is a little green and white braided wire, i believe for power but I do know what im trying to connect it to. Other than that everything should work fine i hope
    Elsewhere
    It goes from J7 on the Opus to the power button header on your motherboard.
    How about the Wiki?
    Dec 2008
    alright but what am I looking for exactly? Is there anyway you could describe it or maybe even send a picture of where it should go?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    c'mon guy, you can't expect to be spoon fed everything. If you look at your motherboard manual, you can figure it out all by yourself. Most every motherboard is different, so there's no way someone can just show you a generic picture of where it goes. It hooks up to the same header that a normal power button would in a normal case.
    Tidder
    Try RevFE
    Elsewhere
    Quote Originally Posted by neiljackson28 View Post
    Have you ever opened up a computer to look at the connections that are made to the motherboard?
    Alternately, have you looked at the manual for your motherboard that indicates where the diagrams are that show you where to connect everything?
    This is where you need to start educating yourself, especially about the equipment you have or plan to use.
    How about the Wiki?
  1. Opus DCX3 120 problem. Fans spin, LED on, no video
    By Gene in forum Power Supplies
    Last Post: 02-27-2008, 07:27 PM
  2. PWR-013 - OPUS 120 watt DC-DC power Supply DCX3.120
    By RedGTiVR6 in forum Power Supplies and Regulators
    Last Post: 02-05-2008, 11:21 AM
  3. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-20-2005, 11:46 PM
  4. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 02:16 AM
  5. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
