You wire it to the yellow & black wires of a hard drive power connector.
Ywllow = 12v
Black = Ground
Hey guys.
so i got everything i need to install the comp.
i'm just not sure how to power the screen.
i got a lilliput 701, and my power supply is an m2 atx.
i was thinking of hooking up the screen to the cigarette plug.
Is that a good place, or should i plug it into the m2 atx?
If i should plug it into the PSU, how do i do it?
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
Why would you keep the regulator on it if its wired to a HDD connector? That's regulated power, so the egg is pointless.
Now, if you wire it straight to the vehicle's electrical system, you certainly need the egg in place.
PRECAUTION, it doesnt hurt to have it their either.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
Most regulators need an excess of power to function properly...
If you use a 7812, 12V regulator, for example, it needs at least 13.5V to work properly.
If you use a 12V vreg and feed it just 12V, you might be asking for problems...
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
I have the 701 and there is no linear voltage regulator on the inside of the egg, so I dont think the "excess power" applies. I think it is just there to smooth out the voltage because inside the egg, all there is, is an inductor and capacitor.
