Results 1 to 10 of 20
Thread: PC line out noise? andd amps
    Oct 2006
    Hey ppl,
    So i wired up my system today for the first time. Anyway all is working fine except i am getting some crackling noise from the computer line out (headphone/speaker socket) and you can hear it in the speakers when the music is either off or turned down.
    However, when i plug my mp3 playing straight into my amp (in place of the computer) i get no noise at all.
    IS this a case for a usb sound card?
    MY other issue is that my system draws 33mA when the ignition is off, i've found this is due to my k500 monitor which i believe it uses to keep the clock time etc stored. Is this an ok amount? or am i just going to drain my battery!
    thanks!
    drummerian
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Is your mp3 running off batteries? If it is, then you might have a ground loop problem. Buy a ground loop isolator, that should fix it.
    I would rewire the monitor to an acc line. That way it wont draw any power when the ignition is off.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    Oct 2006
    amps problem solved!
    anyway back to this, my mp3 was running from batteries, anddd another test i did was to plug my head phones directly to the pcs output. This produced a similar result to the amp! so i am sure the noise is cause by the pc.
    Everything in my system is grouded to the same place.
    Oct 2006
    any ideas anyone?
    Nov 2007
    North Central PA
    How tight is your 3.5mm plug in the audio output of the pc? If that wiggles, it will crack. You could also recheck all of your wire connections. Maybe on is loose.
    Oct 2006
    have checked and it seems fine? the crackling seems to change when i press on my usb touchscreen and it changes when i remove the usb and vga cables from the pc
    Jan 2008
    Dartmouth, MA
    Sounds like some sort of interference. What is powering the PC?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Oct 2006
    car battery
    Jan 2008
    Dartmouth, MA
    Closer to the PC than that... like what power supply?
    Oct 2006
    m2-atx
  1. Car pc noise Not alternator noise. Please help
    By jmkr53900 in forum Car Audio
    Last Post: 01-07-2009, 09:23 PM
