Sounds like the right channel on the amp is bad. Try reversing the input side of the amp. Hook the left audio cable to the right input on the amp, and the right audio cable to the left input on the amp. The hook one sub to the right amp output. Test the sound. Then hook the same sub to the left side and test the sound again. If the right side still only gives you 1/3 the output, your amp is bad.
LinkBack URL
About LinkBacks
