Results 1 to 10 of 14
Thread: help needed motherboard wont fire up
    Feb 2009
    im very new to all this and building my first pc, i have fitted my 12v psu and motherboard, i wanted to make sure these were working before i went any further, the psu definately works, but no life at the motherboard, should there be a connection from the psu to the motherboard that switches it on, apart from the main 20wire connector. here is a diagram
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Is the PSU to MB on/off switch connected? i don't see it..
    Also, does it need the P4 wire to be connected?
    Vendor - Qube colin's Avatar
    Dec 2006
    Quote Originally Posted by alexpez23 View Post
    Yes, there should. Theres a header on your PSU that is equivalent to pressing the "ON" button on a computer case. When the PSU gets power, it knows to "press" that switch which turns your computer on.
    Feb 2009
    do you know how i find out with connection it is on the motherboard
    Sep 2006
    War-Town, GA.
    It is usually a pair of pins sticking up. Short of having a diagram for the MB, follow the wires coming from the computer's on/off switch; you can also tap into those wires.
    Elsewhere
    Read the mothrboard's user manual.
    How about the Wiki?
    Feb 2009
    unfortunately i dont have a manual brought it off ebay
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Which motherboard do you have?
    If you cant DODGE em, RAM em.
    Elsewhere
    Sorry, but that's decidedly weak.
    You can download the manual for damn near any motherboard from the manufacturer's website.
    All you have to do is look, and you'll find what you need.
    How about the Wiki?
    Sep 2006
    War-Town, GA.
    Hold tight, somebody is going to search the web, download the manual, read it, and make a special trip to connect the wire. Just hold on!
  1. M2-ATX with Intel Atom Motherboard Issues
    By jeremy480 in forum M2-ATX
    Last Post: 12-05-2010, 01:28 AM
  2. Motherboard with AGP slot needed
    By stardeala in forum General Hardware Discussion
    Last Post: 02-17-2008, 11:10 AM
  3. CF, PCMCIA, SERIAL motherboard needed! HELP!
    By EricM in forum General Hardware Discussion
    Last Post: 04-24-2005, 01:17 AM
  4. motherboard help needed
    By Holden__V8 in forum General Hardware Discussion
    Last Post: 11-17-2002, 08:09 AM
  5. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 08:56 PM
