Results 1 to 3 of 3
Thread: Sound to car help
    Sound to car help
    Ok so I have been doing a lot of reading and I'm going to start a carpc project for my G35 sedan. The one question I have is about getting sound from the PC to my car.
    I see a lot of posts saying to use an amp and such. But I have a bose premium system in my car and I wanted to know if there was a way to connect the PC to this?
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    you can use an auxiliary input like this one:
    http://cgi.ebay.com/PAC-AAI-NIS2-04-...QQcmdZViewItem
    but be careful to make sure that it is compatible with your radio and harness
    or you can use an FM modulator like this one:
    http://www.amazon.com/Scosche-Audio-...8DK4B8CXGQXZ0Q
    i don't know what year your car is and whether or not it's a sedan or coupe but i would recommend you go to http://www.pac-audio.com/vag.html and input your car specs and check what kits are compatible with your car.
    Variable Bitrate csfile's Avatar
    Feb 2009
    Yes, you can connect the pc to your stock amp.
    You can use a wiring harness. The Metra 70-7551 harness has RCA connections to connect to the PC like this: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7.
    Edit: This is if you are completely replacing the stock headunit. If you are keeping the headunit, the post above is perfect.
  1. IPhone Car Navigation - The Death of your PND
    By Fiberoptic in forum Mp3Car Blog Talk
    Last Post: 04-14-2009, 10:32 AM
  2. Replies: 5
    Last Post: 03-12-2009, 12:48 AM
  3. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
