Results 1 to 10 of 11
Thread: Biggest noob of all need help :)
    May 2009
    Hi amazing site you guys have here im glad to have joined your community and hope to learn over time and hopefully help others once i my self have gained some knowledge tho for now i have no idea.
    i just got my 1st car and i want to put a Car PC in it,
    i bought a VoomPC and a 7" motorized Lilliput in dash monitor
    i have hooked up the monitor to where the old stereo was by rewiring the old harness on to my monitor, tho for the computer i want it to sit in the boot tho i have no idea where to find/run the wires.
    http://www.cartft.com/support_db/sup...les/Voom-2.pdf
    this is the car pc im using an the connector i need to connect is there a way to split any wires in the boot to the harness and what colour are the wires im looking for to split, where is the ignition wire located etc. sorry for the noob question tho this is a area i wouldn't mind getting in to thanks for your time and help.
    btw i do not have a sub or a amplifier just stock speakers that are wired into the monitor which replaced my old stereo and my car is a hyundai excel 2000 model, how ever in the future i will get a new sound system, also here is a link of my monitor.
    http://cgi.ebay.com/ebaymotors/Lilli...fAudioQ5fVideo
    thanks again and sorry for the frustratingly noob question
    Low Bitrate SwiftDeath's Avatar
    Apr 2009
    Chicago, IL
    I'm confused by what information you actually want. Are you asking for the wiring diagrams? What I suggest is to google your car and find others who have added sound systems or see if you can find anybody else on here that added a CarPC to your car. What you are going to have to do is run a good size gauge wire to the trunk from the battery though, that I know for sure, because using the power from any other electrical circuit is extremely dangerous.
    -SwiftDeath
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    Yea you need to run an 8 gauge wire (at least) from the battery, through the firewall (seperates the inside of the car from the engine), under the paneling/carpet and into your trunk. Then You will need another 8 gauge (should be the same size as the power wire) wire to ground the PC to the car chassis.
    To find out which wire is the ignition wire, I would recommend either getting a multimeter and testing the wires from the harness you connected to the monitor, or looking for a wiring diagram for your car.
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Read the FAQ in the nav bar at the top of the forum on how to wire your car pc. That will get you started.
    Want to:
    May 2009
    Thanks alot for the help i have some what a understanding :P so the 8 gauge is the thickness of the wire right ? also i have to run the wire Directly from the battery for the 12v Positive tho how about for the ACC 12v is that classified as the ignition one and also where would be the best place to split that cable and would i also need 8 gauge cable for it.
    thanks
    also what is a distribution block and will i need one.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You don't need thick gauge wire for the ACC 12v. There is very little power drawn from it as it only serves as a signal to the PSU to start and shutdown. You can use a fuse tap and probably get a switched signal from your radio fuse. (You should get and use a digital multimeter for this purpose and also to ALWAYS check polarity and voltage before hooking up your expensive electronics!)
    Google up a distro block and you'll see that it is a device for distributing power from the battery wire to multiple wires.
    Be sure to FUSE everything as described in the FAQs (a fused distro block is a good idea)
    Want to:
    May 2009
    Awsome thanks guys few more questions how many gauges does the ground have to be and can i just use any part of the chassis or does it have to be pulled from the battery. also on my car pc wiring harness i have to orange cables which says AMP RMT GND and AMP RMT what are they for thanks
    May 2006
    NW Pennsylvania
    You really should search for this stuff, but...
    Generally you use the same gauge for ground that you used for power and you need to connect the ground wire to bare metal, use some sandpaper and sand off some paint and connect the wire to the chassis with a screw or something.
    The AMP RMT is amp remote, its equivalent to the ACC 12v. you can use that to turn your computer and/or amp on. That can be a small wire 18-20 gauge or something. I'm guessing the AMP RMT GND is the ground for the remote turn on, not sure what thats for or if you should do anything with it, someone else might know.
    May 2009
    Awsome ok now few more things i need cleared if you guys dont mind thanks, what kind of fuse do i need to buy and for the fuse and distributer block do i place it b4 or after the firewall and also the wires on my wiring harness is much thinner then the 8 gauge battery wire what do i do ? and lastly how do i find out how many watts the car pc pulls thanks and cheers i have learnt alot in a day thank u so much guys lol
  1. Replies: 4
    Last Post: 03-05-2009, 12:36 PM
  2. noob intruducing myself
    By Shott8283 in forum Newbie
    Last Post: 12-25-2005, 10:32 AM
  3. Are there any ebay traders to watch out for?
    By jeeplaw in forum Off Topic
    Last Post: 06-15-2005, 12:10 PM
  4. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
