Save yourself the headache and run a waire straight to the battery.
It's easier than it sounds and you know the gauge of the wires from the power source are suitable for powering your equipment.
If you tap into a fuse box, you are relying on the OEM wiring harness, which could be much thinner (higher gauge) wire that is capable of pushing less amperage. That would create a risk of wires overheating, which is a fire hazard.
Personally, I think running wires back to the battery is the easier method, but others may have different opinions.
LinkBack URL
About LinkBacks
