Results 1 to 5 of 5
Thread: Can I ground my CarPC to my seat rails?
    Newbie armysgt's Avatar
    May 2009
    I know that the chassis is the perfect place for a ground, someone mentioned using a voltmeter to find a ground. A ground would have no current running through it at all right? Well, my main question is can i ground my pc to to the rails holding my seat? I would imagine that's directly bolted to the chassis. I was planning on putting my pc under my seat.
    Elsewhere
    You could, but there are better locations, secifically a bolt fastened directly to the chassis.
    A better option in that area is the bolt that holds the seat to the chassis.
    Be sure to strip paint off the metal that will come in contact with the ground wire to ensure the best possible contact.
    How about the Wiki?
    Newbie V1RUS's Avatar
    May 2008
    Florida
    Yes, you can use the bolt holding the seat, just like DarquePervert said. I currently have my ground attached to a seat bolt in the chassis with no problems, just take a grinder to the area around the bolt so you get a solid connection like he said.
    2005 Silverado - Atom 330 D945GCLF2 - 160GB Hitachi 2.5" HD - 150W Opus PSU - Lilliput 629GL
    Jan 2009
    it is so easy to make a ground...it takes like 3 mins...
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    If you are unsure of a ground, use your wire tester with a know power source. Put the positive probe on a hot wire. Put the negitive probe on the bolt you want to use. If you get a light on, you have ground.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
  1. Replies: 7
    Last Post: 11-25-2007, 07:58 AM
  2. Jokes thread
    By Cris in forum Off Topic
    Last Post: 05-03-2007, 12:24 AM
  3. A couple of questions about the Queue...
    By froalskiner in forum StreetDeck
    Last Post: 12-01-2006, 05:20 PM
  4. A couple questions before I finish install
    By CArringt in forum MacCar
    Last Post: 11-20-2006, 05:26 PM
  5. couple general Audio/video quality questions
    By Vladimer in forum Car Audio
    Last Post: 10-09-2006, 01:54 PM
