Results 1 to 10 of 11
Thread: How to hibernate intel atom carpc
    Jul 2008
    hey guys..
    i just got a car pc a couple of weeks ago (my first one)..
    http://www.vastute.com/index.cgi?car...&pid=101010122
    its got a intel atom D945GCLF2..
    for some reason i cant get either hibernate or standby to be available as an option on the shutdown menu. i have tried it with two different versions of windows: xp home edition service pack 1, and xp professional with service pack 3
    i have tried:
    going into the power options in control panel and there is nowhere to select enable hibernate like ive seen other people do
    also tried going into bios menu and there is nothing there either..
    am i just using the wrong version of windows or could something else be the problem?
    cheers
    Elsewhere
    Have you made sure that S1 and/or S3 power saving modes are enabled in the BIOS?
    Once you do that, you will likely have to reinstall Windoze to have it install all the ACPI options correctly.
    How about the Wiki?
    Jul 2008
    i went into the bios but i couldnt find anything in the menu to do with power saving modes?
    Jul 2008
    i just double check in the bios..
    s3 mode is already enabled..
    is it worth changing this to s1 and reinstallin windows?
    or should i maybe try another version of windows?
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    How much ram do you have installed? If you have too much ram it won't let you, I think its around 6 or 8 gigs though. Try going to Start -> Run and type in (without quotes) "cmd", then type (again no quotes) "powercfg /HIBERNATE on" and see what that says. If it doesn't enable hibernate it should tell you why it couldn't. Hope this helps.
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
    Mar 2009
    this may sound strange....but make sure you have the most up-to date video drivers.
    In 'power options' in 'control panel' - do you have an hibernate tab? If not then it could be your video drivers......has happened to me alot when re-building PC's
    Lewis
    Mar 2006
    Blog Entries
    1
    FYI, I'm using the same motherboard and hibernate works great under Windows XP professional SP3. Sorry, no idea why it doesn't work for you.
    May 2009
    Go to Control Panel/System/Hardware/Device Manager and check for any devices with yellow exclamation mark. That shows driver issues, which may prevent hibernation or stand-by.
    Jan 2009
    subscribed
    Jul 2008
    wow i didnt think the video card could affect this problem..
    i just updated the video driver and what do you know - i can now hibernate..
    thanks so much everyone for your help this has been buggin me for like two weeks and now i got it set up properly!!
    Thanks!
  1. Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By lucegunz in forum General Hardware Discussion
    Last Post: 06-17-2009, 11:06 PM
  2. Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By PORTUGAL in forum General Hardware Discussion
    Last Post: 05-18-2009, 11:05 AM
  3. super dooper intel atom motherboard
    By anam_funny in forum General Hardware Discussion
    Last Post: 05-04-2009, 02:31 PM
  4. Carpc or Carputer Complete Guide
    By smhussain in forum Newbie
    Last Post: 04-21-2009, 06:58 AM
  5. Intel Atom mini-ITX board for sale
    By Phatsacks in forum General Hardware Discussion
    Last Post: 05-30-2008, 06:34 PM
