Results 1 to 10 of 10
Thread: I need help on powering everything (lilliput, wire size, etc) and audio hookups
    Newbie dublee's Avatar
    May 2009
    Hi people,
    I'm planing my install and looking for some advice on my power setup and on connecting everything together.
    since there are multiple inputs & outputs on both headunits, i'm a little confused, but thing i'v figured it out, except how best to add an ipod to the setup.
    The computer has no regulated 12v out for the lilliput monitor, but since it is a headunit would it have its own regulator?
    I'm not sure about the wire gauge or fuses at all, any help here would be welcome.
    Would it be better to feed the 12v acc for the amp from the headunit remote turn on line coming out of the headunit? will this prevent amp thump?
    Here is the power diagram:
    And here is the audio connection diagram:
    Thanks in advance, if you need anymore info on my setup, please let me know.
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    You can connect your Lilli to your psu. Cut the end off one of your molex drive plugs. There will be red, yellow, and black wires. The yellow is 12v, black is ground, red is 5v. Double check with a multimeter.
    Not sure about the thump.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    Low Bitrate skeet2331's Avatar
    Feb 2005
    Indiana
    You can run the acc from your headunit if you would like and that would solve the problem, however PSU like the Opus and M2 or M4atx have a remote turn on wire for the amp. Depending on your PSU i would just take it from there.
    Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
    My 2000 Saturn SL2 Worklog
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    Using the amp turn on from the PSU can sometimes cause your speakers to pop when the PSU turns on the amp that powers them. You could still try using the psu, if it pops then just switch it over to the ignition or the HU, it all depends on what works for you.
    +1 to powering your monitor from the PSU, you just use the yellow wire from one of the 4pin molex connectors.
    If you don't have an available molex connector, you can buy a Y cable that will split it into two connectors(usually come with video cards that need an extra power connection) . You want to let the PSU regulate the power. The fluctuating voltage can cause you monitor's backlight to go prematurely.
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
    May 2009
    Thanks for the feedback,
    I want to be able to run my headunit and amp while the pc is off, so via the headunit is the best option, reading the users manual it says its a soft power up for amps so all's good there.
    I've not opened up the pc, it came assembled, i will soon though and see if there is a spare molex connector.
    This is the 12v regulator i'm using for the bullet cameras.
    Spec: input - DC2V/32V
    output - DC10v/12V1.5A
    If i cut off the 2.1mm DC plug will it provide a positive and negative wire like on the input side? And then use that as regulated power.
    May 2009
    Update:
    I've opened the pc up and i do have a spare molex connector.
    The PSU is a M2-ATX-HV 140w
    Can i use cut both the 5v & 12v lines from the 1 connector to power 2 different things at the same time(12v monitor & 5v Usb hub)?
    Nov 2007
    North Central PA
    You can use both the 12v and 5v line at the same time. Just check the wires with a multimeter like I said before. I have never seen anything other the yellow-12v, red-5v, but you never now.
    Elsewhere
    Quote Originally Posted by dublee View Post
    Update:
    It's actually 160w.
    Yes.
    Yellow = 12v
    Red = 5v
    Black = ground
    How about the Wiki?
    May 2009
    one more question, should i ground my lillyput headunit off one of the ground wires from the molex plug, or ground it to the car chassy as usuall?
    May 2006
    NW Pennsylvania
    Ground it to the chassis.
    Rule of Thumb: Your grounds should be as short as possible.
  1. Biggest noob of all need help :)
    By Austrazilian in forum Newbie
    Last Post: 05-07-2009, 01:38 PM
  2. noob intruducing myself
    By Shott8283 in forum Newbie
    Last Post: 12-25-2005, 10:32 AM
  3. Are there any ebay traders to watch out for?
    By jeeplaw in forum Off Topic
    Last Post: 06-15-2005, 12:10 PM
  4. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
Tags for this Thread
