The red wire is +5v and the black is ground. The flat cable is the SATA cable. So you connect red-to-red and black-to-black using an available power connector from your PSU.
Hi,
i need power conecctors schema off this cable in attachment
on which conecctor power is?
sorry for my bad english![]()
this looks like it is for a slimline sata drive as there are no 3v or 12v lines on the cable
I need marked connectionsi dont have this cable, need this conecction to build it
1 Device Present
2–3 5 V
4 Manufacturing Diagnostic
5–6 Ground
http://en.wikipedia.org/wiki/Serial_ATA
edit: i dont know which side is pin 1 but it would probally be the key side
| 1 2 3 4 5 6|
|_-----------|
ohhhhh thnx![]()
Hello,
I plan to build the power cable, too. Who knows how I have to connect:
pin 1 Device Present
and
pin 4 Manufacturing Diagnostic
mayby pin 1 with 5V and pin 4 with ground ???
Yours faithfully
Chris
No, that's probably a quick way to fry your drive. DO NOT connect pin 1 or pin 4 to anything. Pin 1 doesn't say anything about 5v, and pin 4 says nothing about ground, why would you even think this is correct?
Virac is correct, pin 1 is the key-side.
