Results 1 to 7 of 7
Thread: Using a home pc as car pc?
    May 2009
    Ive searched around here and obviously, im not typing the proper search terms. Basically, ive been building my own home computers for years, but i was interested in getting into the CAR COMPUTER COMMUNITY now.
    Heres my deal, I have a home pc, which is uses a 250 watt power supply. Ive looked around and couldnt find the fallowing information i need.
    -What adapter-or power inverter/converter will i need to plug my pc to the car.
    -how many volts or watts does it have to be.
    -how it may affect my battery.
    -and any option suggestions.
    I deeply appreciate any of your guy's help. I apologize if any of these has been asked before. IF there are posts with the same questions and answer, please feel free to direct me to them.
    thanks.
    -rice
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    moved to the Newbie Section.
    Low Bitrate skeet2331's Avatar
    Feb 2005
    Indiana
    Basically you want to figure out the watts the mobo and everything else pulls. Just because you have a 250 psu on it now does not mean you need that much. I've seen people with 600 watts psu and only use 150 of it.
    A lot of the mini itx boards/cpu/vga combos only consume 10 watts. A lot of 7" touchscreens are around 10 - 15 watts. A M2ATX is 160 watt intelligent ATX startup and shutdown psu for car computing. Also the OPUS range from 120 watts and higher and are prone to less problems then the M series.
    These PSU are designed to startup and shutdown with the car's ign. These will also monitor the car battery and shutdown if the battery levels drop too low so you are able to start your car if need be. Do some and it has all be covered before and check out the FAQ section. If you have questions ask. We will answer.
    Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
    My 2000 Saturn SL2 Worklog
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You searched but must have not checked the FAQ link in the nav bar at the top of the forum. You'll find information about powering computers and how to calculate the necessary power supply size there.
    Also, check out the FAQ emporium. It's a little broader than just the FAQ. You can access it from the link in my signature.
    Want to:
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    As you will soon find if you search other posts, power inverters are not recommended. They waste a lot of power as heat. And from a carputer standpoint, they are not as cool. Get one of the intelligent psu from the store. They are smaller, don't create as much heat, and will turn your pc on and off for you. I use the m4 I got from the store. I actually have two. My wife bought me one for my bday, but I am impatient and bought one a few weeks before.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    May 2009
    rizaydog, can you link me to a specific product? please. Based on your observation, whats good for something that normally uses 250 watt power supply?
    Nov 2007
    North Central PA
    Here is a link for the Opus 320w. I have read a lot of good things about Opus, but have never had one myself.
    http://store.mp3car.com/OPUS_320W_In..._p/pwr-024.htm
    This is what I currently use.
    http://store.mp3car.com/M4_ATX_250W_..._p/pwr-031.htm
  1. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
