Results 1 to 2 of 2
Thread: Rearview cam suggestions?
    Mar 2009
    I am looking to put a rearview camera in my rx8 trunk keyhole position. The issue with this is that it is not in the center of the car, it is on the passenger side. So I want a rather wide angle camera.
    Does anyone have any suggestions for a cheap camera? Also, I prefer a usb one.
    That brings up another question. Is there some adapter that converts like a standard RCA video out into usb in?
    May 2006
    Calgary, Alberta
    1. You can get cameras from anywhere, even a crappy webcam. Or you can try places like dealextreme.com, they have a few for cheap. But you're going to want one that has a mirrored output as well as a wide angle and you'll want CCD, not CMOS, if you want any sort of quality video. And then there's the issue with infrared LED for nighttime use and it goes on.
    2. Why USB? You don't need to record the video (unless you want to), you just need to view it when reversing, right? So just hook it up via RCA and you're good.
    3. There are converters for RCA-USB but they're not going to use all the available functions of USB. Like you won't be able to do data transfer for recording unless you have a capture card and you also won't be able to power the camera that way since RCA doesn't have a 5 volt rail for power.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Rearview Cam Questions .
    By Kevin94bird in forum StreetDeck
    Last Post: 05-05-2008, 10:53 PM
  2. LCD switch to rearview cam automatically
    By iph3w in forum LCD/Display
    Last Post: 12-19-2005, 11:58 AM
  3. Error on USB rearview cam.
    By dougmorgan99 in forum Road Runner
    Last Post: 08-17-2005, 02:54 AM
  4. add code for rearview cam.
    By Custommx3 in forum Road Runner
    Last Post: 02-28-2005, 12:54 AM
  5. peep hole cam as a rearview cam?
    By electron in forum General Hardware Discussion
    Last Post: 11-02-2004, 08:57 PM
