Results 1 to 10 of 10
Thread: Noob DC-DC Question
    Newbie IamDan's Avatar
    May 2009
    Question Noob DC-DC Question
    I better start by introducing myself, Hi i'm Dan and i stummbled across this forum a few weeks ago. I currently own a 2006 Australian/Euro spec ford focus.
    After looking at the mp3Car store I have a few questions before I lay down my hard earned cash. I was looking at one of the bundled systems to build but was wondering what else i would need?
    (Example)
    http://store.mp3car.com/Budget_Bundl..._p/ccc-204.htm
    Will i need a DC-DC converter with this?? Im also curious as to which screen seems to be the easiest to install/setup? I'm not scared of getting my hands dirty as I am a mechanic so the rest should be fairly simple eg: OBDII etc
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by IamDan View Post
    (Example)
    This bundle includes the m2-atx power supply which has a dc-dc converter built in as well as ignition based start up and shut down.
    Screens are very much a car specific thing. Search the faqs, work log(for dashs similar to yours, Check out the double din kit if you have a double din dash.
    Lilliputs are reliable and inexpensive. You might want to look at that as an option. Just remember to power the Lilliput off of a regulated 12v lead supplied by the comptuer PSU. (an extra yellow and black hard drive connector is a great place to tap regulated 12v)
    May 2009
    Thanks for the quick reply.. I did a few quick measurements last night and found my stock head-unit was 230mm X 120mm (9"x4.75"). I sent and e-mail to the people at mp3Car store and they replied extremly quickly with the measurement for the lilliput double din unit but im having trouble reading the mesurement correctly, can anyone give me the sizes with and with bezel?
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Dan, try not to get too hung up on the dimensions. You will need to Take the screen out of the stock case and customize it to fit in your car.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    May 2009
    Sorry mate but it sort of all "hangs" on the screen fitting in the empty hole. The boss (read wife) would not be to happy with me cutting into the dash. I to would like the factory fitted look. Two reasons for this 1)Looks alot better IMHO 2)Gives me options come time to sell the vehicle. I would like to be able to return it to stock should i ever need to sell. BTW thanx heaps for the replies.
    Thanks Dan
    Nov 2007
    North Central PA
    I was talking about customizing the monitor, not your car. Sometimes you can make the lcd case fit into your dash. Other times, you can use a double din installation kit for your make/model car. That is how I did mine. No mods to the car itself.
    Apr 2009
    Newark, New Jersey, United States
    Quote Originally Posted by Fiberoptic View Post
    ..... Just remember to power the Lilliput off of a regulated 12v lead supplied by the comptuer PSU. (an extra yellow and black hard drive connector is a great place to tap regulated 12v)....
    hey question, will distance cause any issue in regards to power?
    my lcd is in the dash above the radio and my carputer is in the trunk.
    thats about 12-13 feet of wire i am going to run.
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by trinybwoy View Post
    It should be ok for the power. I would recommend keeping the ground shorter though.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Thanks Dan
    You may want to message WuNGuN, he drives a Ford Focus also, with your interior. His Bezel looks amazing. Here is the link to his work log.
    WuNgUn PIC'S-Water cooled car PC 95% done!
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Jul 2007
    Miami
    Quote Originally Posted by csfile View Post
    The recommended size of a ground should always be 6 feet or less. I made mine 1 foot. If you dont find a ground point, then make one. Drill a hole and sand away the paint, down to the bare metal and put a bolt.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Real Noob harddrive question
    By matabra in forum Newbie
    Last Post: 07-27-2006, 07:08 PM
  2. noob question about wiring
    By VW_Carputer in forum Newbie
    Last Post: 05-24-2006, 09:33 PM
  3. Total Noob Question
    By free cable pron in forum Newbie
    Last Post: 04-15-2006, 05:01 PM
  4. Very NOOB question...Help Me..
    By KingRichard in forum Newbie
    Last Post: 05-27-2005, 03:40 AM
  5. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
