Results 1 to 4 of 4
Thread: Power Supply Convertor
    May 2009
    St. Louis, MO
    Has anyone used one of these?
    LINK
    If so, what have been the outcomes?
    What are the pros and cons?
    Thanks!
    Jun 2008
    Seattle, WA
    Looks like a Pico-PSU knockoff. I see no mention of intelligent startup-shutdown controller, which is something you want for a car PC. If that's the size you're looking for, you'd be better off with something like the M3-ATX. http://www.mini-box.com/M3-ATX-DC-DC...8&category=981
    An Opus 120w would probably be better.
    If you want to go the PicoPSU route without startup-shutdown controller, then get the real thing, at least then you get full support and warranty: http://www.mini-box.com/s.nl/it.A/id...8&category=981
    Elsewhere
    Pros:
    - It's small.
    Cons:
    - It requires regulated 12v input, which your vehicle does not supply.
    - The power output is pretty meager at 120w max across all 3 rails.
    - No 4-pin P4 12v power cable, not that it is capable of powering anything that would require one.
    - No startup/shutdown controller.
    I suggest reading the FAQs: http://www.mp3car.com/vbulletin/advfaq.php
    There are several write-ups about choosing an appropriate power supply for your project.
    How about the Wiki?
    May 2009
    St. Louis, MO
    Ok thanks.
    After I looked at Kross response, I was thinking about getting the M4-ATX, it seems to be more of what i am looking for.
    Thanks for the help.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. REVIEW::220 Watt DC-DC Power Supply: DSATX
    By seabeggar69 in forum Power Supplies
    Last Post: 03-20-2006, 05:53 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
