Results 1 to 10 of 14
Thread: GPS/XM sharkfin antenna (i really did search)
    Apr 2008
    Hello guys, im nearing completion of my carpc, now im just looking for an antenna that can multi task. Ive been going crazy googleing and searching mp3car. Hopefully all you geniuses can help me. I am looking for a sharkfin style antenna that can do gps and xm. If it can do anything else it would be awesome, but those 2 are my main concern. I saw the antenna that is on mp3store but it doesnt have XM. also if someone can point me in the direction of a gps reciever with capable external antenna that works with centrafuse i would greatly greatly appreciate it!! Thanks again! (and i swear i really did search but could find nothing that pertained to making a new antenna and not using oem or just stuffing the BU353 into a dummy)
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    I have not been through it all, but http://www.badland.co.uk/products.php might have something for you?
    Or you could go for the real deal.. buying the BMW antenna:
    Follow this link: http://www.realoem.com/bmw/showparts...40&hg=65&fg=30 to find what partnumber you want, and then go to your local Bavaria/BMW dealer and order it.
    GSM, GPS and DAB Radio... (and if I'm not mistaken, you ca use the DAB part for your XM).
    Apr 2008
    thank you so much for your help!!! i really really appreciate it. if i could trouble you for one more thing, do you have any recommendations for a gps receiver that can connect to the sharkfin and is compatible with centrafuse? ive been looking for a guide to convert DAB to XM but i cant seem to find anything. Is it a straight connect and DAB is just another name for XM/Sirius? or is there more to it? thanks in advance!
    Nov 2007
    I recently did this..... i bought one of those dummy shark fin for VW opened it up and put my bu-353 in and my xm antenna, I get crappy reception from the xm antenna but i think it was from the twisting and testing the antenna on the base
    the xm (little one ) its upside down....
    May 2006
    Calgary, Alberta
    Can someone explain to me what exactly you're doing here? How do you get the USB cable from the antenna to your computer to send the signal? Is it wireless?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Nov 2007
    in that pic the gps is disconnected thats why there is no cable.. the connector its small enough that fits through the opening of the antenna. now the xm antenna I had to cut it in order to pass the cable through the opening..
    and then just run the cable to the carputer which is the trunk so its not a long run for the cable
    sorry I only took that pic..
    Apr 2008
    does this stay waterproof? im worried if i do this i might damage the antennas. also what gps receiver are you using? I bought the bu 353 cuz it seems to be the most popular one
    Nov 2007
    its been raining a lot down here in florida and everything its still working fine it has a rubber that goes between the car and the antenna that prevents water from going in into the bottom of the antenna.
    my gps its that same one you have the bu-353 I took it out of the enclosure that it has and put inside.
    Apr 2008
    can i ask you one last thing, where did u get the dummy fin? ive been looking at the ones on ebay, the ones that look more like bmw's but there doesnt seem to be enough room underneath for adding anything. im afraid to buy it and figure out it doesnt really fit
    Nov 2007
    just search for "vw shark fin" the one i bought had the am/fm antenna in it but i took it out b/c it did not fit with the others and I hardly use it anyways
  1. Accommodating my GPS and WiFi antenna
    By portabuddy in forum Fabrication
    Last Post: 10-29-2011, 01:44 PM
  2. Search quirk?
    By Silentbob343 in forum Road Runner
    Last Post: 02-02-2006, 09:48 PM
  3. Replies: 0
    Last Post: 08-22-2005, 10:06 AM
